2013 Ford Econoline 250 Alarm/Remote Start, Stereo Wiring
paulr1976
Member - Posts: 9
Posted: October 09, 2014 at 8:28 PM / IP Logged
Hi,
I'm looking for color codes and wiring info for a 2013 Ford E-250 van, for alarm and remote start.
Thanks in advance,
Paul
tonanzith
Gold - Posts: 593
Posted: October 09, 2014 at 9:18 PM / IP Logged
12 Volts     red (fusible link B)     +     Smart Junction Box under driver dash, black 1 pin plug (G), pin 1
Second 12 Volts     blue/red or GREEN/ red (x3) (common 20A)     +     ignition switch, gray 13 pin plug, pins 2, 7, 9
Starter     blue/white     +     ignition switch, gray 13 pin plug, pin 5
Second Starter     N/A
Ignition     WHITE/ orange     +     ignition switch, gray 13 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     BROWN / yellow     +     ignition switch, gray 13 pin plug, pin 8
Second Accessory     PURPLE / green     +     ignition switch, gray 13 pin plug, pin 3
Third Accessory     N/A
Keysense     blue/gray     -     ignition key switch, gray 10 pin plug, pin 10
Data Bus     yellow/orange (TX); PURPLE / gray (RX)     data     PATS Transceiver around ignition key sw, green 4 pin plug, pins 4, 3
The PATS ignition is blue/brown in pin 2, and ground is BLACK/ blue in pin 1.
Can Bus High     gray/orange (MS CAN); WHITE/ blue (HS CAN)     data     data link connector, black 16 pin plug, pins 3, 6
Can Bus Low     PURPLE / orange (MS CAN); white (HS CAN)     data     data link connector, black 16 pin plug, pins 11, 14
Can Bus Sw     N/A
Power Lock     gray / YELLOW     -     driver kick or SJB under driver dash, gray 26 pin plug (C), pin 17
Power Unlock     PURPLE / gray     -     driver kick or SJB under driver dash, gray 26 pin plug (C), pin 4
Lock Motor     gray/brown     5 wire     driver kick or SJB under driver dash, black 32 pin plug (D), pin 6
Driver Unlock Motor     blue/green     5 wire     driver kick or SJB under driver dash, black 32 pin plug (D), pin 28
Passenger Unlock Motor     PURPLE / gray     5 wire     driver kick or SJB under driver dash, black 32 pin plug (D), pin 27
Parking Lights (-)     gray     -     headlight sw or SJB under driver dash, black 52 pin plug (B), pin 31
May need to interrupt the headlight switch ground when triggering this wire. It is BLACK/ blue at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Parking Lights (+)     PURPLE / white     +     driver kick or SJB under driver dash, gray 13 pin plug (E), pin 6
Hazards     BROWN / yellow     -     hazard switch or SJB under driver dash, black 52 pin plug (B), pin 48
Turn Signal (Left)     blue/green (F); gray/brown (R)     +     SJB under dr dash, blk 26 pin plug (F), pin 21; bk 32 pin plg(D), pin25
Turn Signal (Right)     yellow/purple (F); PURPLE / orange (R)     +     SJB under dr dash, blk 26 pin plug (F), pin 23; bk 32 pin plg(D), pin26
Headlight     blue/white     -     headlight sw or SJB under driver dash, black 52 pin plug (B), pin 30
AutoLights     N/A
Reverse Light     blue/white     +     driver kick, harness to rear
Left Front Door Trigger     GREEN/ purple (diode isolate, see Tech Doc 1076)     -     driver kick or SJB under driver dash, gray 26 pin plug (C), pin 14
Right Front Door Trigger     white     -     driver kick or SJB, gray 26 pin plug (C), pin 2
Left Rear Door Trigger     N/A
Right Rear Door Trigger     yellow     -     driver kick or SJB, gray 26 pin plug (C), pin 15
Dome Supervision     gray/purple     +     driver kick or SJB under driver dash, gray 14 pin plug (A), pin 9
Trunk/Hatch Pin     green (rear cargo doors)     -     driver kick or SJB under driver dash, gray 26 pin plug (C), pin 3
Rear Glass Pin     N/A
Hood Pin     N/A
Trunk/Hatch Release     N/A
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     N/A
Factory Alarm Disarm     N/A
Disarm No Unlock     N/A
Trunk Alarm Shunt     N/A
Tachometer     NOT blue     ac     any fuel injector
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     PURPLE / green     +     fuel pump relay in battery junc box on driv fender
On stripped chassis models, also found at the inertia fuel shutoff switch under the driver dash.
Rear Defroster     N/A
Mirror Defroster     N/A
Left Front Heated Seat     N/A
Right Front Heated Seat     N/A
Speed Sense     PURPLE / orange (except stripped chassis models)     ac     driver kick, harness to rear
Brake Wire     PURPLE / white     +     brake switch or SJB under driver dash, black 52 pin plug (B), pin 40
Parking Brake     WHITE/ purple     -     park brake sw or SJB under driver dash, gray 26 pin plug (C), pin 1
Horn Trigger     blue/white     -     horn switch or SJB under driver dash, black 52 pin plug (B), pin 41
Wipers     blue/orange (L); PURPLE / orange (H); blk/blu (grnd)     -     wiper switch, black 6 pin plug, pins 6, 1, 5
Left Front Window (Up/Down)     blue/gray - yellow/purple     A     master window switch, gray 8 pin plug, pins 5 - 1
Right Front Window (Up/Down)     BROWN / yellow - GREEN/ orange     A     driver kick, door harness
Left Rear Window (Up/Down)     N/A
Right Rear Window (Up/Down)     N/A
Sun Roof (Open/Close)     N/A
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     WHITE/ red     +     radio, gray 24 pin plug, pin 1
Radio Ground     BLACK/ gray     -     radio, gray 24 pin plug, pin 13
Radio Ignition     blue (base radio only; MS CAN on premium)     +     radio, gray 24 pin plug, pin 2
Radio Illumination     PURPLE / gray (base radio only; MS CAN on premium)     + dimmer     radio, gray 24 pin plug, pin 3
Factory Amp Turn-on     yellow/purple     +     radio, gray 24 pin plug, pin 7
Power Antenna     N/A
Left Front Speaker (+/-)     white - WHITE/ brown or green - gray     +,-     radio, gray 24 pin plug, pins 8 - 21
On models with amplifier, the speaker wires are white - WHITE/ brown at the amplifier behind center of dash, black 14 pin plug, pins 13 - 6.
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange or purple - yellow     +,-     radio, gray 24 pin plug, pins 11 - 12
On models with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the amplifier behind center of dash, black 14 pin plug, pins 11 - 4.
Left Rear Speaker (+/-)     WHITE/ green - BROWN / yellow or GREEN/ brn - gray/brn     +,-     radio, gray 24 pin plug, pins 9 - 22
On models with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier behind center of dash, black 14 pin plug, pins 12 - 5.
Right Rear Speaker (+/-)     BROWN / white - BROWN / blu or PURPLE / brn - yellow/blu     +,-     radio, gray 24 pin plug, pins 10 - 23
On models with amplifier, the speaker wires are BROWN / white - BROWN / blue at the amplifier behind center of dash, black 14 pin plug, pins 10 - 3.
Center Channel (+/-)     N/A
Subwoofer (+/-)     N/A
Aux. Audio Input Left (+/-)     blue - YELLOW /GREEN (without SYNC)     +,-     radio, gray 16 pin plug, pins 7 - 8
Aux. Audio Input Right (+/-)     blue/green - WHITE/ green (without SYNC)     +,-     radio, gray 16 pin plug, pins 6 - 14
RSE Video (+/-)     brown - BROWN / yellow (rear view camera)     +,-     radio, gray 10 pin plug, pins 1 - 6
RSE Audio Left (+/-)     blue - gray/orange (SYNC audio)     +,-     radio, gray 16 pin plug, pins 1 - 2
RSE Audio Right (+/-)     PURPLE / green - BROWN / wht (SYNC audio)     +,-     radio, gray 16 pin plug, pins 9 - 10
Satellite Radio 12 Volts     (built into radio)
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     double DIN center of dash
Left Front Speaker     6 x 8     4     left front door
Left Front Tweeter     N/A
Right Front Speaker     6 x 8     4     right front door
Right Front Tweeter     N/A
Left Rear Speaker     6 x 8     4     left rear cargo door
Left Rear Tweeter   left rear side panel
Right Rear Speaker     6 x 8     4     right rear cargo door
Right Rear Tweeter   right rear door
Center Channel     N/A
Subwoofer     N/A
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
Gary Sather
mendozer
Member - Posts: 21
Posted: November 14, 2016 at 10:08 AM / IP Logged
is this the same for a 2014 as well?
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
