I'm having trouble wiring the remote starter and the dball2 together in my 2006 mustang gt. I have tried connecting the RS to the car and left the key in the ignition and tried that way but no success. Here is the layout.
Main Harness (H1), 6-pin connector
H1/1 RED (+)12VDC CONSTANT INPUT-----------------Lt.Grn/Purple
H1/2 BLACK (-) CHASSIS GROUND-----------------------Ground to Chassis
H1/3 BROWN (+) SIREN OUTPUT-------------------------Siren
H1/4 WHITE/ BROWN PARKING LIGHT ISOLATION WIRE - PIN 87a of onboard relay------Need Help??
H1/5 WHITE PARKING LIGHT OUTPUT-------------------------------Blk/Lt.Green
H1/6 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT---------------Need Help??
H2 Harness, 24-pin connector
H2/1 PINK/WHITE (-) 200mA IGNITION/FLEX RELAY CONTROL OUTPUT------------------not used??
H2/2 BLACK/ WHITE (-) NEUTRAL SAFETY INPUT------------------------------------------------Ground to Chassis
H2/3 BLUE/WHITE (-) 200mA 2ND STATUS /REAR DEFOGGER OUTPUT---------------- Need Help??
H2/4 GREEN/ BLACK (-) 200mA OEM ALARM DISARM OUTPUT-----------------------------Lt.Blue/Blk
H2/5 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT-------------Need Help??
H2/6 GREEN (-) DOOR TRIGGER INPUT (N/C* OR N/O)------------------------Lt.GREEN/ YELLOW
H2/7 BLACK / YELLOW (-) 200mA DOME LIGHT SUPERVISION OUTPUT--------
H2/8 BROWN / BLACK (-) 200mA HORN HONK OUTPUT------ not used
H2/9 DARK BLUE (-) 200mA STATUS OUTPUT-----Not used
H2/10 PINK (-) 200mA IGNITION 1 OUTPUT--------------------------not used when installing remote start??
H2/11 WHITE/ BLACK (-) 200mA AUX 3 OUTPUT--------------------not used
H2/12 VIOLET (+) DOOR TRIGGER INPUT---------------------------------------not used
H2/13 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT-------------------------------not used
H2/14 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT-------------------------------not used
H2/15 ORANGE / BLACK (-) 200mA AUX 4 OUTPUT-----------------------------not used
H2/16 BROWN (+) BRAKE SHUTDOWN INPUT---------------------------- Lt.Green(switch above brake pedal)
H2/17 GREY (-) HOOD PIN INPUT (N/C OR N/O)---------------------------- not used
H2/18 VIOLET / YELLOW (-) 200mA STARTER OUTPUT---------------------not used??
H2/19 BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT (N/C OR N/O)---------not used
H2/20 GREY/BLACK (-) DIESEL WAIT TO START INPUT-------------------------------not used
H2/21 WHITE/ BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION INPUT-------not used
H2/22 ORANGE (-) 200mA ACCESSORY OUTPUT-----------------------------------not used
H2/23 VIOLET/WHITE TACHOMETER INPUT--------------@ Fuel Injector
H2/24 GREEN / WHITE (-) 200mA OEM ALARM ARM OUTPUT---------------------Lt.Blue/Pink
Remote Start, (H3) 10-pin connector
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT------------------------WHITE/ yellow(ignition switch)
H3/2 RED / WHITE (87) FLEX RELAY +12V INPUT (30A FUSED)----------not used
H3/3 ORANGE (+) ACCESSORY OUTPUT------------------------BLACK/ Pink( ignition switch)
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)—DarkGreen(@ ignition switch starter side)
H3/5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL)------DarkGreen(@ ignition switch keyside)
H3/6 RED IGNITION 1 +12V INPUT (30A FUSED)----------------------------LightGREEN/ Purple(ignition switch)
H3/7 PINK/WHITE (30) FLEX RELAY OUTPUT (car side of ign, acc or starter wire)----------------not used
H3/8 PINK/BLACK (87a) FLEX RELAY INPUT (key side of ign, acc or starter wire if needed)----not used
H3/9 RED / BLACK ACCESSORY/STARTER RELAY +12V INPUT (30A FUSED)------------not used
H3/10 NC No Connection----------------------------not used
Door Lock, 3-pin connector
1 BLUE (-) 500mA UNLOCK OUTPUT---------------------------DarkBlue/LightGreen
2 EMPTY NOT USED-----------not used
3 GREEN (-) 500mA LOCK OUTPUT----------------------------WHITE/ Purple
Dball2 in D2D mode
10-pin
9:Pink (+) Ignitio Input............................WHITE/ yellow
12-pin
10: Yellow/Black.....................WHITE/ light green
11: ORANGE / black.....................gray/orange
14-pin
7:gray/black..........................BLACK/ pink
8:yellow................................LightGREEN/ YELLOW(RS side of door trigger)
9:orange / YELLOW....................LightGREEN/ YELLOW(car side of door trigger)
12:BROWN / red.........................WHITE/ yellow
___________________________________
usn
usn
