need 2014 scion xb remote start-alarm dia
mazda 6t9
Member - Posts: 33
Posted: October 19, 2014 at 7:38 PM / IP Logged
Need a 2014 scion xb alarm and remote start diagram.
Checked on idatalink and no chipped key bypass showed up for them so must not have them?
Platinum - Posts: 7,787
Posted: October 19, 2014 at 8:03 PM / IP Logged
ReadyRemote has the wiring info :  http://www.readyremote.com/main.asp?make=Scion&model=xB
Fortin lists the 2014 Scion xB :  http://fortin.ca/en/vehicles/scion/xb/2014/     Not sure if they all have transponders.  Check for a "G" stamped on the key.
tonanzith
Gold - Posts: 593
Posted: October 19, 2014 at 8:28 PM / IP Logged
12 Volts     white (30A)     +     ignition switch, white 8 pin plug, pin 7
Second 12 Volts     yellow (7.5A)     +     ignition switch, white 8 pin plug, pin 2
Starter     white     +     ignition switch, white 8 pin plug, pin 8
Second Starter     white     +     ignition switch, white 8 pin plug, pin 1
Ignition     gray     +     ignition switch, white 8 pin plug, pin 6
Second Ignition     white     +     ignition switch, white 8 pin plug, pin 4
Third Ignition     N/A
Accessory     black     +     ignition switch, white 8 pin plug, pin 3
Second Accessory     N/A
Third Accessory     N/A
Keysense     blue     -     key switch or dash fuse box, white 32 pin plug (2E), pin 23
Data Bus     pink (RX); green (TX) (Canadian models only)     data     Transponder Key Amplifier on ign switch, black 7 pin plug, pins 4, 5
The immobilizer light is yellow (+) at the instrument cluster, white 24 pin plug, pin 15. The IMO - IMI are lt. green to lt. GREEN/ black - pink, high above and behind the dash fuse box, gray 18 pin plug, pins 18 - 17, or at the Engine Control Module next to underhood fuse box, black 60 pin plug, pins 10 - 11.
Can Bus High     lt. green     data     data link connector, white 16 pin plug, pin 6
Can Bus Low     white     data     data link connector, white 16 pin plug, pin 14
Can Bus Sw     white (SIL)     data     data link connector, white 16 pin plug, pin 7
Power Lock     blue     -     driver kick, white 18 pin plug, pin 16
Power Unlock     yellow     -     driver kick, white 18 pin plug, pin 15
Lock Motor     beige     5 wire     driver kick, white 18 pin plug, pin 8
Driver Unlock Motor     lt. green     5 wire     driver kick, white 18 pin plug, pin 17
Passenger Unlock Motor     lt. blue     5 wire     dash fuse box, white 18 pin plug (2H), pin 18
Parking Lights (-)     white     -     headlight switch, white 20 pin plug, pin 18
Parking Lights (+)     green     +     dash fuse box, white 30 pin plug (2A), pin 29
Hazards     gray     -     hazard switch, gray 4 pin plug, pin 4
Turn Signal (Left)     yellow     +     dash fuse box, white 30 pin plug (2A), pin 27
Turn Signal (Right)     lt. blue     +     dash fuse box, white 30 pin plug (2A), pin 28
Headlight     black or green     -     headlight switch, white 20 pin plug, pin 20
AutoLights     N/A
Reverse Light     red     +     dash fuse box, white 30 pin plug (2A), pin 30
Left Front Door Trigger     white     -     driver kick or dash fuse box, white 30 pin plug (2A), pin 21
Right Front Door Trigger     brown     -     pass kick or dash fusebox, wh 32P plg (2E), pin 20
Left Rear Door Trigger     lt. blue     -     driver kick, white 13 pin plug, pin 10
Right Rear Door Trigger     lt. green     -     pass kick or dash fusebox, wh 32P plg (2E), pin 19
Dome Supervision     white     -     dash fuse box, white 6 pin plug (2K), pin 2
Trunk/Hatch Pin     lt. green     -     driver kick or dash fuse box, white 30 pin plug (2A), pin 7
Rear Glass Pin     N/A
Hood Pin     N/A
Trunk/Hatch Release     beige (rear handle switch)     -     driver kick, white 13 pin plug, pin 3
Trunk Release Motor     red     5 wire     driver kick, white 13 pin plug, pin 2
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     lt. blue (driver door key lock)     -     driver kick, white 18 pin plug, pin 7
Factory Alarm Disarm     pink (driver door key unlock)     double -     driver kick, white 18 pin plug, pin 6
Disarm No Unlock     (use keysense)
Trunk Alarm Shunt     N/A
Tachometer     gray     ac     data link connector, white 16 pin plug, pin 9
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     lt. green     +     clutch switch, black 2 pin plug, pin 1
Fuel Pump     lt. green     +     dash fuse box, white 30 pin plug (2A), pin 8
Rear Defroster     black     - latched     A/C Control Assembly, gray 10 pin plug, pin 2
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     N/A
Right Front Heated Seat     N/A
Speed Sense     purple     ac     radio, white 20 pin plug, pin 3
Brake Wire     blue     +     brake switch or dash fuse box, white 30 pin plug (2A), pin 9
Parking Brake     black     -     parking brake switch or dash fuse box, white 16 pin plug (2C), pin 5
Horn Trigger     lt. green     -     horn switch or dash fuse box, white 32 pin plug (2E), pin 5
Wipers     black (LO); red (HI); blue (ignition)     +     wiper switch, white 10 pin plug, pins 3, 4, 2
Left Front Window (Up/Down)     pink - white     A     power window master switch, white 18 pin plug, pins 3 - 4
Right Front Window (Up/Down)     green - brown     A     driver kick, blue 12 pin plug, pins 11 - 6
Left Rear Window (Up/Down)     red - blue     A     driver kick, blue 12 pin plug, pins 8 - 3
Right Rear Window (Up/Down)     green - brown     A     driver kick, blue 12 pin plug, pins 7 - 12
Sun Roof (Open/Close)     N/A
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     lt. blue     +     radio, white 10 pin plug, pin 4
Radio Ground     brown     -     radio, white 10 pin plug, pin 7
Radio Ignition     gray     +     radio, white 10 pin plug, pin 3
Radio Illumination     green (parking lights); white (dimmer)     +,-     radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5
Factory Amp Turn-on     N/A
Power Antenna     beige     +     radio, white 10 pin plug, pin 8
Left Front Speaker (+/-)     pink - purple     +,-     radio, white 10 pin plug, pins 2 - 6
Right Front Speaker (+/-)     lt. green - blue     +,-     radio, white 10 pin plug, pins 1 - 5
Left Rear Speaker (+/-)     black - yellow     +,-     radio, white 6 pin plug, pins 2 - 6
Right Rear Speaker (+/-)     red - white     +,-     radio, white 6 pin plug, pins 1 - 3
Center Channel (+/-)     N/A
Subwoofer (+/-)     N/A
Aux. Audio Input Left (+/-)     black - red     +,-     radio, white 20 pin plug, pins 17 - 16
Aux. Audio Input Right (+/-)     white - red     +,-     radio, white 20 pin plug, pins 15 - 16
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
Item     Size     Depth     Location
Headunit     double DIN center of dash
Left Front Speaker     6.3 left front door
Left Front Tweeter     1 left front door
Right Front Speaker     6.3 right front door
Right Front Tweeter     1 right front door
Left Rear Speaker     5.5 left rear door
Left Rear Tweeter     N/A
Right Rear Speaker     5.5 right rear door
Right Rear Tweeter     N/A
Center Channel     N/A
Gary Sather
tonanzith
Gold - Posts: 593
Posted: October 19, 2014 at 8:30 PM / IP Logged
Xpresskit dball or dball2 or trusty old 556u
Gary Sather
mazda 6t9
Member - Posts: 33
Posted: October 19, 2014 at 9:04 PM / IP Logged
Thank you guys very much.
