12 Volts RED / green (30A) + BCM above driver kick, blue 27 pin plug, pin 4
Second 12 Volts N/A
Starter yellow (for starter kill only) + starter or underhood fuse box, gray 32 pin plug (X3), pin 28
Second Starter wht/pur (r-code); wht/blk (5V ref) (Tech Doc 1605) +9.6K ohms ignition sw or BCM above driv kick, green 25 pin plug, pins 15, 22
Ignition PURPLE / black + ignition switch or BCM above driv kick, green 25 pin plug, pin 6
Second Ignition N/A
Third Ignition N/A
Accessory purple / YELLOW + ignition switch or BCM above driv kick, green 25 pin plug, pin 5
Second Accessory (same as second starter) +6.3K ohms
Third Accessory N/A
Keysense (same as second starter)
Data Bus GREEN/ purple (immobilizer LIN bus) data immobilizer mod or BCM above driv kick, green 25 pin plug, pin 2
Can Bus High blue (high speed GMLAN) data data link connector or BCM above driv kick, white 26 pin plug, pin 25
Can Bus Low white (high speed GMLAN) data data link connector or BCM above driv kick, white 26 pin plug, pin 24
Can Bus Sw green (low speed GMLAN) data data link connector or BCM above driv kick, blue 27 pin plug, pin 22
Power Lock BROWN / yellow - BCM above driver kick, pink 27 pin plug, pin 15
Power Unlock BROWN / white - BCM above driver kick, gray 26 pin plug, pin 14
Lock Motor BROWN / yellow 5 wire BCM above driver kick, pink 27 pin plug, pin 4
Driver Unlock Motor gray 5 wire BCM above driver kick, pink 27 pin plug, pin 1
Passenger Unlock Motor gray 5 wire BCM above driver kick, pink 27 pin plug, pin 2
Parking Lights (-) GREEN/ gray - headlight switch or BCM above driver kick, wht 26 pin plug, pin 22
Parking Lights (+) PURPLE / gray (L); gray/brown (R) + BCM above driver kick, black 26 pin plug, pins 6, 5
Hazards GREEN / WHITE - BCM above driver kick, blue 27 pin plug, pin 26
Turn Signal (Left) blue/white (F); blue/white (R) + BCM above driver kick, brown 26 pin plug, pins 2, 1
Turn Signal (Right) GREEN/ purple (F); blue/purple (R) + BCM above driver kick, black 26 pin plug, pins 3, 4
Headlight WHITE/ purple - headlight switch or BCM above driver kick, wht 26 pin plug, pin 16
AutoLights GREEN/ brown (ground to turn off autolights) - headlight switch or BCM, white 26 pin plug, pin 11
Reverse Light GREEN / WHITE + BCM above driver kick, gray 26 pin plug, pin 3
Left Front Door Trigger gray - BCM above driver kick, pink 27 pin plug, pin 22
Right Front Door Trigger gray - BCM above driver kick, pink 27 pin plug, pin 13
Left Rear Door Trigger gray - BCM above driver kick, pink 27 pin plug, pin 27
Right Rear Door Trigger gray - BCM above driver kick, gray 26 pin plug, pin 11
Dome Supervision gray + BCM above driver kick, gray 26 pin plug, pin 1
Trunk/Hatch Pin PURPLE / gray - BCM above driver kick, pink 27 pin plug, pin 5
Rear Glass Pin N/A
Hood Pin BROWN / green - BCM above driver kick, black 26 pin plug, pin 24
Trunk/Hatch Release blue (lock); green (unlock) (w/o power door locks) - BCM above driver kick, pink 27 pin plg, pin 15; gry 26 pin plg, pin 14
Trunk Release Motor (same as lock motor and passenger unlock motor)
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm yellow/brown (driver door key lock) - BCM above driver kick, gray 26 pin plug, pin 19
Factory Alarm Disarm blue/purple (driver door key unlock) - BCM above driver kick, gray 26 pin plug, pin 13
Disarm No Unlock (transponder and ignition)
Trunk Alarm Shunt N/A
Tachometer GREEN/ YELLOW, BROWN / yel, yellow/wht, or BROWN / pur ac above fuel rail, black 8 pin plug, pin E, F, G, or H
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal yellow (see Tech Doc 10001) resistor clutch switch, black 3 pin plug, pin B
Fuel Pump gray + underhood fuse box, black 44 pin plug (X2), pin 36
Rear Defroster blue/white - BCM above driver kick, blue 27 pin plug, pin 14
Mirror Defroster (same as rear defroster)
Left Front Heated Seat BROWN / gray + latched driver seat heating switch, 6 pin plug, pin 3
Right Front Heated Seat yellow/blue + latched passenger seat heating switch, 6 pin plug, pin 3
Speed Sense yellow/purple (CVT); BROWN / white (M/T) ac TCM, black 24 pin plug, pin 16; ECM, black 56 pin plug, pin 27
Brake Wire PURPLE / white or WHITE/ yellow + BCM above driver kick, black 26 pin plug, pin 11
Parking Brake blue/purple - BCM above driver kick, gray 26 pin plug, pin 15
Horn Trigger BROWN / white - BCM above driver kick, brown 26 pin plug, pin 19
Wipers gray + BCM above driver kick, black 26 pin plug, pin 16
Left Front Window (Up/Down) GREEN/ gray - yellow/purple A dr window sw, wht 6 pin plug, pins 5 - 2 or wht 14 pin plug, pins 9 - 7
Right Front Window (Up/Down) yellow/black - BROWN / yellow A driver kick, door harness
Left Rear Window (Up/Down) GREEN/ gray - BROWN / blue A driver kick, door harness
Right Rear Window (Up/Down) GREEN/ gray - BROWN / blue A driver kick, door harness
Sun Roof (Open/Close) N/A
Sun Roof (Limit/Close) N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12V RED / blue + radio, black 44 pin plug, pin 44
Radio Ground black - radio, black 44 pin plug, pin 38
Radio Ignition (low speed GMLAN)
Radio Illumination (low speed GMLAN)
Factory Amp Turn-on N/A
Power Antenna N/A
Left Front Speaker (+/-) blue - BROWN / blue +,- radio, black 44 pin plug, pins 40 - 32
Right Front Speaker (+/-) yellow - yellow/black +,- radio, black 44 pin plug, pins 39 - 31
Left Rear Speaker (+/-) green - GREEN/ black +,- radio, black 44 pin plug, pins 42 - 34
Right Rear Speaker (+/-) white - blue/black +,- radio, black 44 pin plug, pins 41 - 33
Center Channel (+/-) N/A
Subwoofer (+/-) N/A
Aux. Audio Input Left (+/-) gray - brown +,- radio, black 44 pin plug, pins 24 - 23
Aux. Audio Input Right (+/-) green - brown +,- radio, black 44 pin plug, pins 10 - 23
RSE Video (+/-) blue - BLACK/ white (aux video) +,- radio, black 44 pin plug, pins 21 - 22
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts (built into radio)
Satellite Radio Ground N/A
Satellite Radio Ignition N/A
Satellite Radio Antenna N/A
Satellite Audio Left (+/-) N/A
Satellite Audio Right (+/-) N/A
Item Size Depth Location
Headunit irregular center of dash
Left Front Speaker 3.5 2.5 left front dash
Left Front Tweeter N/A
Right Front Speaker 3.5 2.5 right front dash
Right Front Tweeter N/A
Left Rear Speaker 6 x 9 4 left rear strut tower
Left Rear Tweeter N/A
Right Rear Speaker 6 x 9 4 right rear strut tower
Right Rear Tweeter N/A
Center Channel N/A
Subwoofer N/A
Left Front Headrest
Gary Sather
