avital 4103 on 2006 ranger
seanp
Posted: November 14, 2014 at 3:46 PM / IP Logged
have it wired up nothing works except the panic button. i had to run universal door lock atuators that i tested with a bettery and they work fine. its a base model ranger. i dont get it?
Platinum - Posts: 7,786
Posted: November 14, 2014 at 4:27 PM / IP Logged
What did you use as the transponder bypass module?  You didn't list your location but all U.S. market vehicle have an ignition immobilizer system.
Did the power lock add-on come as a kit with a controller or relays?
Might help if you gave us some more info.  Here is the 4103 connector listing, just add the vehicle wires you connected to :
Avital 4103
H1/1  LIGHT GREEN/ BLACK  FACTORY ALARM DISARM
H1/2  GREEN / WHITE  FACTORY REARM
H1/3  YELLOW  (+) IGNITION OUT (TO ALARM)
H1/4  WHITE/ BLUE  (-) ACTIVATION INPUT
H1/5  ORANGE  (-) GROUND WHEN LOCKED
H1/6  BROWN  (-) HORN OUTPUT
H1/7  RED / WHITE  (-) TRUNK RELEASE OUTPUT
H1/8  BLACK  GROUND
H1/9  WHITE  (+/-) LIGHT FLASH
H2/1  BLACK/ WHITE  (-) NEUTRAL SAFETY SWITCH INPUT
H2/2  VIOLET/WHITE  TACHOMETER INPUT WIRE
H2/3  BROWN  (+) BRAKE SWITCH SHUTDOWN WIRE
H2/4  GRAY  (-) HOOD PINSWITCH SHUTDOWN WIRE
H2/5  BLUE/WHITE  (-) 200mA 2ND STATUS/REAR DEFOGGER OUTPUT
4-pin satellite harness diagram
1  BLUE  STATUS OUTPUT
2  ORANGE  (-) ACCESSORY OUTPUT
3  PURPLE  (-) STARTER OUTPUT
4  PINK  (-) IGNITION OUTPUT
Heavy gauge relay wiring diagram
1  PINK  (+) (30 AMP) OUTPUT TO IGNITION CIRCUIT
2  PURPLE  (+) (30 AMP) OUTPUT TO STARTER CIRCUIT
3  ORANGE  (+) (30 AMP) OUTPUT TO ACCESSORY CIRCUIT
4  RED  (+) (30A) HIGH CURRENT 12 INPUT
5  PINK/WHITE  (+) PROGRAMMABLE OUTPUT FOR ACCESSORY OR IGNITION
6  RED  (+) (30A) HIGH CURRENT 12V INPUT
Door lock harness, 3-pin connector
1  BLUE  (-) UNLOCK OUTPUT
2  EMPTY  NOT USED
3  GREEN  (-) LOCK OUTPUT
seanp
Posted: November 14, 2014 at 4:50 PM / IP Logged
h1/2/3 not connected. h1/4 not connected h1/5 orange not connected h1 redwhite not ocnnected
the door locks came seperate i have only the driver door hooked up directly to the blue green on the module. maybe this is wrong. idk. i dont relaly care wether or not the locks work just the remote start
i also dont have a bypass module. its a base model 2006 ranger no chip key
Posted: November 14, 2014 at 5:16 PM / IP Logged
I was thinking of something like this :
H1/1  LIGHT GREEN/ BLACK  FACTORY ALARM DISARM         Not Used
H1/2  GREEN / WHITE  FACTORY REARM          Not Used
H1/3  YELLOW  (+) IGNITION OUT (TO ALARM)   Not Used
H1/4  WHITE/ BLUE  (-) ACTIVATION INPUT       Not Used
H1/5  ORANGE  (-) GROUND WHEN LOCKED   Not Used
H1/6  BROWN  (-) HORN OUTPUT         Yellow/Lt. Green to Dk. Blue (-)  @ clockspring switch plug
H1/7  RED / WHITE  (-) TRUNK RELEASE OUTPUT         Not Used
H1/8  BLACK  GROUND             Chassis Ground
H1/9  WHITE  (+/-) LIGHT FLASH   ** 4103 jumper set to (+)       Brown (+)   @ SJB, Brown plug, Pin 8
ETC......
For the added lock actuator solenoids you will need relays and a circuit like this Actuators / Reverse Polarity diagram :
https://www.the12volt.com/doorlocks/page3.asp#arp
If the truck starts with a plain metal key, then no bypass is needed.
And just for the record, it is an automatic transmission, right?
Posted: November 14, 2014 at 6:10 PM / IP Logged
At a guess you've already fried the lock/unlock circuit.
Ever thought of doing research and or any testing before installing?
tejarillo
Member - Posts: 21
Posted: November 16, 2014 at 9:49 PM / IP Logged
For your door locks actuator to work you need a pair of relays and wiring diagram A found here in the forum in relays section and for the remote start to work you need a bypass regardless of the trim of the vehicle in some cases like mine you don't need a bypass BUT you still need to do some modifications in the ignition of the truck.
I install a avital 5103 on a 04 Chevy Colorado all works great no bypass but I had to cut a wire in the ignition harness to stop the passlock from triggering
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
