2012 vw tiguan/autostart 2471tw-fm
specs
Copper - Posts: 120
Posted: November 17, 2014 at 5:51 PM / IP Logged
This will be the first time for me doing the key wrap method required by VW vehicles. Planning on using DB-ALL bypass module (understand works quite well in VW applications, plus I have the programming harness for the Directed bypass products)...is there any better choices? Also, as far as wrapping the key and the ignition cylinder, could someone advise on type of wire to use and best method of securing it to key and ignition cylinder. Thank you, Al
Posted: November 17, 2014 at 6:58 PM / IP Logged
Thin wire as per Xpresskit instructions. Use Scotch 33+ tape to secure it.
specs
Copper - Posts: 120
Posted: November 17, 2014 at 7:32 PM / IP Logged
Thks for the quick response Howie....understand how to wrap the key and cylinder, just not sure on the type of wire to use (gauge, insulated or not). Thks again, Al
Posted: November 18, 2014 at 2:13 AM / IP Logged
22, or similar.
specs
Copper - Posts: 120
Posted: November 20, 2014 at 9:32 PM / IP Logged
Ok, have some 22 gauge wire(solid core, copper)....do the sections wrapped around the key head and ignition barrel need to have the insulation stripped back? Al
Posted: November 21, 2014 at 12:06 AM / IP Logged
Insulated.
specs
Copper - Posts: 120
Posted: November 21, 2014 at 4:18 PM / IP Logged
Thks again Howie...Al
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
