2006 scion xb dei 535t
irji619
Member - Posts: 6
Posted: December 18, 2014 at 9:25 PM / IP Logged
I installed a dei 535t in my scion xb. I tried getting into the learn routine but I can not get into learn routine. My window switches are not working.   But the windows roll up and down from my remote.   Can anyone help me?   Thank you to any one that can.
irji619
Member - Posts: 6
Posted: December 29, 2014 at 11:03 AM / IP Logged
Does anyone have an answer to this.   I want the 535t to operate my front windows only for up and down
irji619
Member - Posts: 6
Posted: December 29, 2014 at 12:19 PM / IP Logged
Can anyone help me out with my 535t install on 2006 scion xb? Had anyone installed one of these successfully in that vehicle?
chev104275
Gold - Posts: 1,428
Posted: December 29, 2014 at 12:52 PM / IP Logged
I've never done that car but maybe listing out the connections you've made will help figure it out.
irji619
Member - Posts: 6
Posted: December 29, 2014 at 5:15 PM / IP Logged
H2-7
Whitvoiolek - GREEN / WHITE switch side passenger down
H2-6
BROWN / black - RED / blue switch side passenger up
H2-2
White - GREEN / WHITE switch side driver down
H2-1
Brown - RED / blue switch side driver down
H1-8
Blue/black - RED / blue motor side passenger up
H1-7
GREEN/ black - GREEN / WHITE motor side passenger down
H1-3
Blue - RED / blue motor side driver up
H1-2
Green - GREEN / WHITE motor side driver down
H3-2, H3-1, H1-6, H1-5, H1-1
WHITE/ black, white, violet/black, black, violet
All to ground
The drivers window has factory one touch down.   The rest of the windows are normal up and down.
irji619
Member - Posts: 6
Posted: December 29, 2014 at 5:16 PM / IP Logged
And the orange wire is connected to ground when armed and the RED / white to RED / white of auxiliary 2
Posted: December 29, 2014 at 5:19 PM / IP Logged
Try wiring directly to the motor wires in each door, BUT I did a UK build Yaris recently that had one shot on the driver's side, the door module was built directly on to the motor so I left the driver's door alone.
irji619
Member - Posts: 6
Posted: December 29, 2014 at 8:32 PM / IP Logged
I need to get my hands on a 530t. How did you get it to program without the driver door hooked up? I would really like to get the 535t to work correctly. And my scion is the same as that yaris with module built on motor. I will wire directly into the door tonight or tomorrow.   Thank you.
Posted: December 30, 2014 at 2:27 AM / IP Logged
It was a 530, we don't have the 535 here yet.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
