tundra r/s idatalink tpms wires
adkalex
Member - Posts: 13
Posted: March 01, 2015 at 9:05 PM / IP Logged Link to Post Post Reply Quote adkalex
Hello, noob here. Great info on this site!
I am installing a r/s in my 2015 tundra with idatalink. I found the tpms wire behind the glove box.
My question is the wires from the idatalink are way too short to make it over to the tpms connector (j31) behind the glove box.
Do I need to extend the 2 wires so they reach or is there another place to pick up the tpms wire?
Thanks in advance to any help I receive.
Platinum - Posts: 13,667
Posted: March 01, 2015 at 9:28 PM / IP Logged Link to Post Post Reply Quote i am an idiot
TPMS = Tire Pressure Monitoring System?
tedmond
Gold - Posts: 4,610
Posted: March 01, 2015 at 9:41 PM / IP Logged Link to Post Post Reply Quote tedmond
You will have to extend the wires over. Just match the wire gauge size and you should be fine. Depending on the unit, generally the length of the tach and siren wire are ample to reach the other side.
IAAI, the connection is a SIL data connection. The easiest place to get this wire is at the TPMS module itself which communicates with the car.
Ted
Compustar Expert
adkalex
Member - Posts: 13
Posted: March 02, 2015 at 5:40 AM / IP Logged Link to Post Post Reply Quote adkalex
Thank you, I thought I was missing something:)
Chris Luongo
Platinum - Posts: 3,746
Posted: March 02, 2015 at 7:33 AM / IP Logged Link to Post Post Reply Quote Chris Luongo
I do the same thing as Tedmond does---tach, hood, and siren wires are all just the right length!
TIP: You don't have to take out the glove box.
Under the glove box, above the driver's feet, is a black plastic panel. A couple of screws at the leading edge.
Take out the screws, and then if you pull a little and look carefully, you'll see how the panel is also clipped in near where the screws were. Use a flathead screwdriver or pick tool to release the clips.
After that panel comes down (you don't even really have to remove it, just drop it down and let it hang) look up, around the middle area. The TPMS is right there. Unplug the connector and it comes down with enough slack to work.
I'd suggest keeping the engine off and the key out of the ignition while the connector to the TPMS is unplugged.
Posted: March 02, 2015 at 10:02 AM / IP Logged Link to Post Post Reply Quote howie ll
"I'd suggest keeping the engine off and the key out of the ignition while the connector to the TPMS is unplugged"
Chris that should be written on every job sheet/vehicle test sheet tundra r/s idatalink tpms wires -- posted image.
