2015 Odyssey Remote Start
nubnubz3215
Posted: April 25, 2015 at 10:50 PM / IP Logged Link to Post Post Reply Quote nubnubz3215
Mark Mizenko wrote:
Look closely at the wire side of the connector, you'll see PIN numbers stamped in the plastic for the pins on the end. IE #1 and 12 on a 24 pin connector. But like Howie said, OBD connectors and usually showen differently.
That message is normal under remote start as BGB stated. And if you unlock hop in and restart too quickly. Does that message appear if you start it Normally?
I did look closely, however I didn't see the numbers stamped on the pin, which I found odd. And the message is on all the time, whether started regularly or remote started.
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
