2012 honda civic unlocks doors after remote star
luism21
Member - Posts: 16
Posted: May 11, 2015 at 5:23 PM / IP Logged Link to Post Post Reply Quote luism21
I finished an installation on 2012 honda civic everything works great just that when i remote start it the doors unlock and when i try to lock it with the alarm remote it wont let it lock. Any clue on what it might be?
dairyboy3
Copper - Posts: 52
Posted: May 11, 2015 at 5:27 PM / IP Logged Link to Post Post Reply Quote dairyboy3
What system and what bypass was used? Are you trying to unlock it with the factory remote? If so the factory remote will not work while the vehicle is running.
luism21
Member - Posts: 16
Posted: May 11, 2015 at 5:49 PM / IP Logged Link to Post Post Reply Quote luism21
I installed the autopage 730 and alca as bypass im using the autopage remote to lock it
dairyboy3
Copper - Posts: 52
Posted: May 11, 2015 at 6:33 PM / IP Logged Link to Post Post Reply Quote dairyboy3
Did you hook up the lock/unlock wires to through the bypass like the install guide shows? If so hard wire them to the lock/unlock wires in the driver kick without going through the bypass and see if that works. Or you should be able to go into the Bypasses advanced settings and set it up to re-arm after remote start so you don't have to manually lock it with the remote. Sounds like it is set up to disarm before remote start(if it has a factory alarm) but not set up to re-arm after remote start.
tedmond
Gold - Posts: 4,610
Posted: May 11, 2015 at 11:09 PM / IP Logged Link to Post Post Reply Quote tedmond
you need to get the lock and unlock wires in the kick panel. Grey loom plenty of slack
Ted
Compustar Expert
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
