needed Compustar CS700-AS & Fortin EVO-ALL
lucianm1971
Posted: June 10, 2015 at 10:18 AM / IP Logged Link to Post Post Reply Quote lucianm1971
Glad to know you guys! New on this forum and with a big problem. Bought a Fortin EVO-ALL and a Compustar CS700-AS for my 2010 Toyota Prius and cannot get them to communicate by D2D port. First installed EVO-ALL and everything is perfect. I can also remote start the car as it's one of the features provided by this. Anyway reprogramed EVO-ALL and used the schematics from Fortin site to connect the Compustar to it. Problem is that it does not work. Compustar & Fortin do not communicate. All wires in place but nothing. Tried all 3 modes on Fortin port - Fortin, APO and lastly D2D... nothing. What am I doing wrong?
Thank you all for your time reading this. Any help will be greatly appreciated.
tedmond
Gold - Posts: 4,610
Posted: June 10, 2015 at 7:53 PM / IP Logged Link to Post Post Reply Quote tedmond
cs700as does not support fortin through d2d, however you can set the fortin for idatalink and use the d2d. perform a reset of the evo-all, turn the idatalink option on, power cycle the cs700 and program the bypass.
Ted
Compustar Expert
lucianm1971
Posted: June 11, 2015 at 1:40 AM / IP Logged Link to Post Post Reply Quote lucianm1971
Thank you for you reply Ted, but as I said in the beginning I'm new to this, actually is my first attempt to mount this on a car by myself. Right now EVO-ALL is on AP Datlink/OFA Datalink as you can see in the attached picture. Wires are set like in Fortin schematics (attached). Only solid black on schematics wired. When I power the Compustar, EVO is not receving power through D2D... Do I have to wire all cables? Also the ones with dotted lines in schematics? Is an alarm/remote started that will successfully only the D2D port from Fortin and 2 - 3 wires to get the job done?
Best regards.
needed Compustar CS700-AS & Fortin EVO-ALL - Last Post -- posted image.
lucianm1971
Posted: June 17, 2015 at 8:32 AM / IP Logged Link to Post Post Reply Quote lucianm1971
somebody?
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
