2006 Nissan navara wiring
is200_turbo
Copper - Posts: 86
Posted: August 17, 2015 at 12:14 AM / IP Logged Link to Post Post Reply Quote is200_turbo
Hi I'm looking for the alarm/remote start information for a Nissan navara this is the model with satnav and an auto
Been advised the bcm maybe playing up so a canbus option isn't the route I want to go down would rather old school wire it in
Many thanks
Posted: August 17, 2015 at 4:15 AM / IP Logged Link to Post Post Reply Quote howie ll
You won't need a CAN module, all straightforward hard wire plus key in box, I did one 4-5 years ago, quite easy just can't remember the colours. Two ignitions and 2 starter wires.
is200_turbo
Copper - Posts: 86
Posted: August 21, 2015 at 4:41 PM / IP Logged Link to Post Post Reply Quote is200_turbo
Well looks like I won't be doing it just yet damaged my tendons in my arm at work so looks like I will stager the install
Going to fit new boot triggers maybe a proximity dedicated in the rear load area ?
Be good if I can get hold of all the colours prior to starting if anyone else has them I know Howard knows his stuff and a top guy from when we met a few years back :)
Posted: August 21, 2015 at 7:18 PM / IP Logged Link to Post Post Reply Quote howie ll
Nothing listed,you have to suck it and see.
I got a 650 and an Intellistart behind the instrument panel.
If the cargo area is covered you won't need door switches, just use an ultrasonic, much more effective than a Prox.
is200_turbo
Copper - Posts: 86
Posted: November 01, 2015 at 2:59 AM / IP Logged Link to Post Post Reply Quote is200_turbo
Where is the best place to grab a tach signal from in these ?
Posted: November 01, 2015 at 3:01 AM / IP Logged Link to Post Post Reply Quote howie ll
Think I did an injector, alternative behind rev counter unless it's data or use a DEI tach generator, most effective.
is200_turbo
Copper - Posts: 86
Posted: November 01, 2015 at 5:15 AM / IP Logged Link to Post Post Reply Quote is200_turbo
Cheers will re route to the engine bay I have the directed wiring guide and says diagnostic plug but that can't be right lol
Then again the wires indicated for the door locks don't match either
Posted: November 01, 2015 at 5:58 AM / IP Logged Link to Post Post Reply Quote howie ll
That's what BMW and Toyota do, pin 9 if it's there.
is200_turbo
Copper - Posts: 86
Posted: November 01, 2015 at 7:43 AM / IP Logged Link to Post Post Reply Quote is200_turbo
Hiya yeah that's what I thought so for now I have done it from the injector not worth faffing with the cluster
Still no luck on door locks it says it's a -pulse on 2 wires but I'll be buggered if I can find em now have checked all the colours on the block directed refer to in terms of what it should be and no joy
Posted: November 01, 2015 at 7:51 AM / IP Logged Link to Post Post Reply Quote howie ll
Go for the motor wires. You'll probably end up doing differential/priority that way. Lock wires at the BCM?
