2010 Santa Fe, Code Alarm RS and keyless
jgarcia1925
Copper - Posts: 57
Posted: August 17, 2015 at 5:59 PM / IP Logged Link to Post Post Reply Quote jgarcia1925
just a simple question...
does the 2010 Santa Fe need an immobilizer bypass? I am fairly certain none is needed, but currently having a brain fart. doing a simple Code Alarm with keyless on it. Idatalink says it needs one, but this looks to be the standard key which if i remember correctly does not require one.
any input is great. thanks!
kaezoo
Copper - Posts: 125
Posted: August 18, 2015 at 9:22 AM / IP Logged Link to Post Post Reply Quote kaezoo
Hyundais sold in the US do not use immobilizer systems. Hyundai vehicles made for the Canadian market have immobilizers. I install in Michigan and haven't yet run into a standard key Hyundai with an immobilizer system, so I doubt you'll need one.
jgarcia1925
Copper - Posts: 57
Posted: August 18, 2015 at 9:49 AM / IP Logged Link to Post Post Reply Quote jgarcia1925
Thanks man. Yeah that's what I thought. Install should be easy on this bad boy. Thanks!
jgarcia1925
Copper - Posts: 57
Posted: August 24, 2015 at 4:10 PM / IP Logged Link to Post Post Reply Quote jgarcia1925
just wondering if someone can clarify this a bit more... i havent worked on this hyundai in a while, but i dont recall having this issue or having to do this.
https://www.the12volt.com/installbay/forum_posts.asp?tid=132384&get=last#709744
is this needed to do to all the santa fe's of this model year? looking at the wiring it doesnt seem that bad, pretty straight forward install. doing a code alarm CA5154 on one soon. its just a keyless and remote start.
thanks guys, for all the help and insight.
