2015 Ford Transit 250 false trigger issue
desh187
Copper - Posts: 310
Posted: August 21, 2015 at 12:12 PM / IP Logged Link to Post Post Reply Quote desh187
Installed Omega Proline AL100 Factory Keyless Upgrade Alarm on 2015 Transit 250 (full size) and using dome light wiring(yellow/gray - at BCM) which i used with a relay to avoid false trigger.
Alarm still goes off every hour or so.Individual wires are (N.C)and i dont have a diagram for this set up.
I have done another 3 of the same vehicle with one relay and they are all fine.Its not the shock sensor either as i have left it unplugged.
Thanks for any feedback on this.
Platinum - Posts: 13,667
Posted: August 21, 2015 at 7:59 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Audiovox has the following info on that vehicle
All Doors     BLACK/ LIGHT BLUE     (+)     IN HARNESS IN DRIVERS KICKPANEL
Posted: August 22, 2015 at 7:46 AM / IP Logged Link to Post Post Reply Quote howie ll
Why not try a diode into the wire idiot gave you, between your joint and the BCM,diode between joint and BCM.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
