2015 Sienna, Python 5706
507 w
Member - Posts: 19
Posted: August 21, 2015 at 2:47 PM / IP Logged Link to Post Post Reply Quote 507 w
Hello again, I want to install a python 5706 on another vehicle, sienna 2015. What bypass module do I need? Thank you
The Broken Link
Posted: August 22, 2015 at 6:56 AM / IP Logged Link to Post Post Reply Quote howie ll
Go to Xpresskit.com, same answer for your other post.
507 w
Member - Posts: 19
Posted: November 13, 2015 at 3:23 PM / IP Logged Link to Post Post Reply Quote 507 w
Everything works after I installed using dball module. Except when i open the sliding door, the engine shutdown. The remote transmitter shows the engine still running. Can I fix this . Thanks
The Broken Link
507 w
Member - Posts: 19
Posted: November 13, 2015 at 5:56 PM / IP Logged Link to Post Post Reply Quote 507 w
Correction, remote shutdown if open any door. This is a push start vehicle
The Broken Link
507 w
Member - Posts: 19
Posted: November 13, 2015 at 6:05 PM / IP Logged Link to Post Post Reply Quote 507 w
If I disable st-door. Will this fix it? Will try tomorow
The Broken Link
Platinum - Posts: 7,783
Posted: November 13, 2015 at 7:58 PM / IP Logged Link to Post Post Reply Quote kreg357
That is normal on PTS vehicles. The remote started engine will shutdown as soon as any door is opened. There are several places in the DB-ALL2 install guide where this is noted. See the top Page 2 of the Quick Reference Guide at the end of the install guide.
507 w
Member - Posts: 19
Posted: November 13, 2015 at 10:40 PM / IP Logged Link to Post Post Reply Quote 507 w
Thanks for the comfirmation. Learned something today: when in doubt read the whole thing! :)
The Broken Link
