Linear actuator controller wiring
phantome46
Member - Posts: 11
Posted: September 05, 2015 at 9:12 AM / IP Logged Link to Post Post Reply Quote phantome46
I have installed a linear actuator to lift my bonnet up on my car.
Currently I have a linear actuator wired directly back to a 7 channel remote controller - this control box has 2x 30amp relays built in which basically when you press and hold button 1 the actuator extends and when you press button 2 and hold it closes.
I wanted to get to a position where you could press the button 1 and it fully opened and then pressed the second button once and it full closes.
To aid this I bought a Spal linear actuator controller - https://www.surpluscenter.com/_MoreSpecs/i5-1577-c.pdf
Now here is where the problem starts!
The Spal controller requires 5 wires to go to the actuator - i think its made to be used exclusively with the correct Spal actuator (which I do not have)
instead I have a linear actuator with 3 wires
exactly like the set up below - http://www.surpluscenter.com/Electrical/Relays-Contactors-Solenoids/DC-Relays-Contactors-Solenoids/12-VDC-7-CHANNEL-WIRELESS-REMOTE-CONTROL-11-3305.axd
Is there a way to connect the 2 things together to accomplish what I am trying to do?
Or could the experts advise how I can achieve what I am trying to achieve in a different way?
Thanks in advance
Phantom
pts760
Copper - Posts: 403
Posted: September 06, 2015 at 10:51 AM / IP Logged Link to Post Post Reply Quote pts760
what actuator are you using? I underdatnd its 3-wire but how is it wired so i can understand how your setup is working
I drink current, eat ohms, and bleed voltage
phantome46
Member - Posts: 11
Posted: September 12, 2015 at 9:36 AM / IP Logged Link to Post Post Reply Quote phantome46
Thanks for the reply. I am not sure what actuator i am using it seems to have only 2 wires going to it brown and yellow. These are both 12v
From the 7 channel controller - channels 1 & 2 are the 30 amp relays - they have 5 pins (from left to right these are)
Yellow +ve
Brown +ve
Red +v permanent live
Orange - Ground
Purple - Ground
Does that help?
Can this be integrated into the remote system?
phantome46
Member - Posts: 11
Posted: September 22, 2015 at 4:54 PM / IP Logged Link to Post Post Reply Quote phantome46
bump for some help please?
phantome46
Member - Posts: 11
Posted: October 26, 2015 at 6:44 PM / IP Logged Link to Post Post Reply Quote phantome46
does anyone have any suggestions on how i might fix this issue?
beegbie
Copper - Posts: 341
Posted: October 31, 2015 at 8:14 PM / IP Logged Link to Post Post Reply Quote beegbie
I looks like the 5 wire ones have reference wires to let the controller know where it's at. If that's the case, you can't use your actuator. I probably would have just used a couple of timer relays instead. You could dial in the time they output to open and close.
beegbie
Copper - Posts: 341
Posted: October 31, 2015 at 8:44 PM / IP Logged Link to Post Post Reply Quote beegbie
Or you could use limit switches.
Wednesday, May 22, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
