Latching Relay or simpler solution
steve392
Member - Posts: 17
Posted: September 15, 2015 at 1:12 PM / IP Logged Link to Post Post Reply Quote steve392
If I use the remote entry, it will provide a 500 milliamp momentary ground pulse. I would use it with a diode protected relay, the same as for the door and trunk locks.
Ween
Platinum - Posts: 1,366
Posted: September 15, 2015 at 9:21 PM / IP Logged Link to Post Post Reply Quote Ween
I would test the solenoid for current draw. May need to boost the output of the remote entry system, either by transistor or another relay.
steve392
Member - Posts: 17
Posted: September 16, 2015 at 11:03 AM / IP Logged Link to Post Post Reply Quote steve392
I think I'll go with a relay according to the "Weak Negative Output to Strong Ground Output" diagram....It will provide a degree of separation between the sensitive electronics of the remote entry and the larger current draw of the solenoid relay....
Thanks for your help, much appreciated.
Posted: September 16, 2015 at 11:55 AM / IP Logged Link to Post Post Reply Quote howie ll
If you do that diode your relay across the coil, 1N4004, band side to coil +.
