Reusing gm bypass & which one best
fwoodjr
Member - Posts: 7
Posted: September 30, 2015 at 6:26 PM / IP Logged Link to Post Post Reply Quote fwoodjr
I have three used gm bypass units and am going to install just remote start no alarm on my 07 envoy Denali
Features I would like would be
auto heated seats on
Integrate start to oem key fob (would be nice but doesn't matter if I cant)
Rear defrost
And I read some where that it's possible to have the climate either go hot or cold depending on temp.
Here are my three units available
Idatalink ads-al (32)
Flash logic fldl1 (16)
Fortin can-sl-pl
Can I performe master reset is units where previously used not on this vehicle using the method described in the manual or will a trick way be needed?
And come some one tell me the difference between the three and which is best? Thank you in advance
fwoodjr
Member - Posts: 7
Posted: October 06, 2015 at 4:31 PM / IP Logged Link to Post Post Reply Quote fwoodjr
Any one?
rs specialist
Copper - Posts: 175
Posted: October 07, 2015 at 6:54 PM / IP Logged Link to Post Post Reply Quote rs specialist
The first to products can be reflashed for your vehicle. The features you are wanting would need to be wired in from the remote start as the bypass will not control them.
The Fortin piece will not work on your vehicle.
The ADS and Flashlogic piece will need to be flashed for the vehicle specific firmware and the only way to do that is to have an account with those companies and the specific flasher.
