2004 Mercedes 230 Kompressor Wiring
puertorico
Posted: October 07, 2015 at 3:58 PM / IP Logged
Hi Im looking for this diagram for an alarm install please help me cannot find it!!!
Nestor PR
tonanzith
Gold - Posts: 593
Posted: October 10, 2015 at 10:00 PM / IP Logged
2004 Mercedes Benz C Class (W203)      DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     RED / purple (20A)     +     Electronic Ignition Switch, plug (C), pin 1
Second 12 Volts     red (125A)     +     driver dash fuse box
Starter     purple (for starter kill only)     +     underhood fuse box, 5 pin plug (C17), pin 1
Second Starter     N/A
Ignition     pink/red (for ignition sense only)     + low curr     Electronic Ignition Switch, plug (C), pin 2
Second Ignition     N/A
Third Ignition     N/A
Accessory     N/A
Second Accessory     N/A
Third Accessory     N/A
Keysense     N/A
Data Bus     N/A
Can Bus High     BROWN / red     data     CAN distribution connector under driver dash
Can Bus Low     brown     data     CAN distribution connector under driver dash
Can Bus Sw     N/A
Power Lock     (CAN bus)
Power Unlock     (CAN bus)
Lock Motor     black     5 wire     Left Front Door Module, plug (C4), pin 3
Driver Unlock Motor     red     5 wire     Left Front Door Module, plug (C4), pin 2
Passenger Unlock Motor     red     5 wire     Right Front Door Module, plug (C4), pin 2
Parking Lights (-)
Parking Lights (+)     gray/black (LF), gray/red (RF)     +     underhood fuse box, 28 pin plug (C6), pins 2 and 3
     The LR - RR wires are gray/black - gray/red at the trunk fuse box, 16 pin plug (C14), pins 6 and 2.
Hazards     (CAN bus)
Turn Signal (Left)     BLACK/ white (LF)     +     underhood fuse box, 28 pin plug (C6), pin 8
     The LR wire is BLACK/ white at the trunk fuse box, 16 pin plug (C14), pin 9.
Turn Signal (Right)     BLACK/ green (RF)     +     underhood fuse box, 28 pin plug (C6), pin 7
     The RR wire is BLACK/ green at the trunk fuse box, 16 pin plug (C14), pin 12.
Headlight     yellow/black (L), yellow (R)     +     underhood fuse box, 6 pin plug (C5), pins 4 and 6
AutoLights
Reverse Light     gray/blue     +     trunk fuse box, 16 pin plug (C14), pin 8
Left Front Door Trigger     BROWN / gray     -     trunk fuse box, 12 pin plug (C2), pin 6
Right Front Door Trigger     BROWN / blue     -     trunk fuse box, 12 pin plug (C2), pin 11
Left Rear Door Trigger     BROWN / pink     -     trunk fuse box, 12 pin plug (C2), pin 10
Right Rear Door Trigger     BROWN / white     -     trunk fuse box, 12 pin plug (C2), pin 12
Dome Supervision     (CAN bus)
Trunk/Hatch Pin     BROWN / yellow or yellow     -     trunk fuse box, 28 pin plug (C21), pin 16 or 18
Rear Glass Pin     N/A
Hood Pin     BROWN / red     -     hood switch or underhood fuse box, 10 pin plug (C3), pin 7
Trunk/Hatch Release     green     -     trunk fuse box, 28 pin plug (C21), pin 15
     Meter this wire while opening the luggage compartment from the handle on the rear of the vehicle.
Trunk Release Motor     white     5 wire     trunk fuse box, 28 pin plug (C21), pin 21 or 22
Fuel Door Release     YELLOW /GREEN or yellow/blue     5 wire     trunk fuse box, 4 pin plug (C13), pin 3 or 2
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     factory remote only
Factory Alarm Disarm     factory remote only
Disarm No Unlock
Trunk Alarm Shunt     N/A
Tachometer     gray/stripe     ac     any fuel injector
     Can also use GREEN/ YELLOW at the underhood fuse box, 28 pin plug (C6), pin 23.
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     brown (in), PURPLE / white or BROWN / pink (out)     - N.O.     clutch switch, 2 pin plug, pins 1 and 2
Fuel Pump     BLACK/ brown or BLACK/ green     +     trunk fuse box, 7 pin plug (C1), pin 3
Rear Defroster     black     + latched     trunk fuse box, 5 pin plug (C20), pin 5
Mirror Defroster     (CAN bus)
Left Front Heated Seat     BLACK/ gray     5 wire     heated seat switch, plug (C5), pin 2
Right Front Heated Seat     BLACK/ purple     5 wire     heated seat switch, plug (C5), pin 1
Speed Sense     BLACK/ green or BLACK/ gray     ac     underhood fuse box, 10 pin plug (C7), pin 8 or 10
Brake Wire     RED / purple (functions with ignition on only)     +     brake switch, 4 pin plug, pin 2
Parking Brake     BROWN / black     -     parking brake switch, 2 pin plug, pin 2
Horn Trigger     BLACK/ white     +     underhood fuse box, 10 pin plug (C3), pin 2
Wipers     green (L), red (H)     +     underhood fuse box, 4 pin plug (C16), pins 3 and 4
Left Front Window (Up/Down)
Right Front Window (Up/Down)
Left Rear Window (Up/Down)
Right Rear Window (Up/Down)
Sun Roof (Open/Close)
Sun Roof (Limit/Close)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Radio 12V     RED / blue     +     radio, 8 pin plug, pin 4
Radio Ground     brown     -     radio, 8 pin plug, pin 8
Radio Ignition     (CAN bus)
Radio Illumination     (CAN bus)
Factory Amp Turn-on     blue/black (MOST wake up) radio, 10 pin plug, pin 4 or 18 pin plug, pin 10
Power Antenna     black     +     radio, 8 pin plug, pin 5
Left Front Speaker (+/-)     green - BROWN / green     +,-     radio, 8 pin plug, pins 5 and 6
     If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are green - BROWN / green at the amplifier, 26 pin plug, pins 13 and 21.
Right Front Speaker (+/-)     orange - BROWN / orange     +,-     radio, 8 pin plug, pins 3 and 4
     If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are orange - BROWN / orange at the amplifier, 26 pin plug, pins 22 and 14.
Left Rear Speaker (+/-)     pink - BROWN / pink     +,-     radio, 8 pin plug, pins 7 and 8
     If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are pink - BROWN / pink at the amplifier, 26 pin plug, pins 23 and 15.
Right Rear Speaker (+/-)     white - BROWN / white     +,-     radio, 8 pin plug, pins 1 and 2
     If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are white - BROWN / white at the amplifier, 26 pin plug, pins 25 and 17.
Center Channel (+/-)     gray - BROWN / gray     +,-     amplifier, 26 pin plug, pins 16 and 24
Subwoofer (+/-)     paralleled with rear speakers
     If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the subwoofer wires are purple - BROWN / purple (1); yellow - BROWN / yellow (2) at the amplifier, 26 pin plug, pins 19 and 11; 20 and 12.
Aux. Audio Input Left (+/-)     black - brown     +,-     radio, 18 pin plug, pins 13 and 5
Aux. Audio Input Right (+/-)     yellow - brown     +,-     radio, 18 pin plug, pins 4 and 5
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     RED / black     +     Satellite Radio Control Unit, 3 pin plug, pin 2
     If equipped, the Satellite Radio Control Unit is in the right side of the luggage compartment.
Satellite Radio Ground     brown     -     Satellite Radio Control Unit, 3 pin plug, pin 1
Satellite Radio Ignition     blue/black (MOST wake up) Satellite Radio Control Unit, 3 pin plug, pin 3
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     (MOST bus)
Satellite Audio Right (+/-)     (MOST bus)
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.5 left front door
Left Front Tweeter   left front door
Right Front Speaker     6.5 right front door
Right Front Tweeter   right front door
Left Rear Speaker     6.5 left rear door
Left Rear Tweeter   left rear door
Right Rear Speaker     6.5 right rear door
Right Rear Tweeter   right rear door
Center Channel   top center of dash
Subwoofer     9 top center of rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner   right side of luggage compartment
Gary Sather
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
