Viper 4105V Transmitters Function Differently
needabeer
Member - Posts: 13
Posted: December 06, 2015 at 6:07 PM / IP Logged Link to Post Post Reply Quote needabeer
I just installed a Viper 4105V into my 2003 Honda Element using a PKALL. Everything works as it should except my transmitters. I have the 4105 programmed to honk on lock/unlock and RS to activate after two button presses. One transmitter does just that, the other unlock/locks with no honk and activates RS on one press. I reset the transmitters within the 4105 and reprogrammed only to have it function the same. Any ideas? Thank you.
rs specialist
Copper - Posts: 175
Posted: December 07, 2015 at 11:29 AM / IP Logged Link to Post Post Reply Quote rs specialist
If you have a bit writer, you can change the remotes to act differently from each other. You may need to change the save to remote 0 instead of 1-4
needabeer
Member - Posts: 13
Posted: December 07, 2015 at 12:31 PM / IP Logged Link to Post Post Reply Quote needabeer
I do have a bitwriter, so I will look into that. Thanks.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
