15 Tacoma Avital 4113 w/dball2
beegbie
Copper - Posts: 341
Posted: January 02, 2016 at 8:16 PM / IP Logged Link to Post Post Reply Quote beegbie
beegbie wrote:
Do a shutdown diagnostic and report back.
pts760
Copper - Posts: 403
Posted: January 02, 2016 at 8:23 PM / IP Logged Link to Post Post Reply Quote pts760
beegbie wrote:
How is that possible if the unit won't respond?
I drink current, eat ohms, and bleed voltage
beegbie
Copper - Posts: 341
Posted: January 03, 2016 at 7:30 AM / IP Logged Link to Post Post Reply Quote beegbie
It's specifically why shutdown diagnostics are built into the unit. It will tell you exactly why the unit isn't responding!
If you try it and get no response, it means you should check power, ground, override button operation, and ignition. If all those test properly then we can assume the unit is bad. A defective unit is extremely rare.
pts760
Copper - Posts: 403
Posted: January 03, 2016 at 10:15 AM / IP Logged Link to Post Post Reply Quote pts760
Read the full post this has already been discussed
beegbie
Copper - Posts: 341
Posted: January 03, 2016 at 1:12 PM / IP Logged Link to Post Post Reply Quote beegbie
Then it's pretty simple. If you have power, ground, ignition, and a good programming button and it won't respond to shutdown diagnostics. The brain is bad. I've just never seen one go bad like this. I'm sure if you get a replacement everything will be fine.
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
