Headlights dimming
ptrone12
Posted: December 21, 2015 at 1:38 PM / IP Logged Link to Post Post Reply Quote ptrone12
I have a 2006 Dodge Ram 1500 and have 3 10" subs, 2 amps for the subs and one amp for the speakers. I have very bad headlight dimming and bad voltage drop even with my lights off. I'm trying to figure out the best route to take. I have a second battery I could hookup but I keep hearing that only really benefits with the car off which I rarely do. I'm trying to find the best solution without breaking the bank. I have already done the big 3 upgrade and replaced my starting battery with an xs power battery. Would a distribution block make any difference along with something else? I am trying to find a solution without replacing my alternator just yet
rs specialist
Copper - Posts: 175
Posted: December 21, 2015 at 2:43 PM / IP Logged Link to Post Post Reply Quote rs specialist
Depends on how much current your amps are pulling. If they are pulling more than the system can sustain, then you will need to upgrade the alternator. Light dimming will always be an issue as the charging system has no way of knowing when it will have the added demand to it. Having an extra battery will help as it is just a giant reserve of energy. Just make sure to properly separate the battery from the system when not in use.
DYohn
Moderator - Posts: 10,741
Posted: December 23, 2015 at 3:25 PM / IP Logged Link to Post Post Reply Quote DYohn
Upgrade the Big 3 (see Hot Topics forum) and consider installing a high output alternator. Nothing else will solve the problem.
ferds
Member - Posts: 11
Posted: January 20, 2016 at 10:57 PM / IP Logged Link to Post Post Reply Quote ferds
Since you have the battery start with that. If that doesn't help consider the big 3 and probably start saving for the high output alternator.
forbidden
Platinum - Posts: 5,352
Posted: February 15, 2016 at 12:29 AM / IP Logged Link to Post Post Reply Quote forbidden
Also read the What is a proper ground sticky.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
