OK so if I bought a Digital Multimeter..
Mr Akimoto
Member - Posts: 14
Posted: May 26, 2003 at 12:27 PM / IP Logged
what would I do with it?
I am installing a DEI Avital 2200 in my Mazda Miata. I think I have located the correct wires to spice into. So the question is what would I do with a digital multimeter (DMM)?
The voltages in the ignition wiring harness, assuming they are hot or constant,  should all be 12V+, since the battery is 12V? I guess the real question is are there some tests I want to perform with my DMM to ensure my alarm system will function correctly or will prevent any potential installation disasters?
I absolutely want to get one if it will prevent any problems or headaches. BTW I saw a nice small one made by GB Instruments at Lowes for $22!
Ciao
Chaser
Member - Posts: 31
Posted: May 26, 2003 at 4:00 PM / IP Logged
Basicaly you would normaly use a DMM to check the wires you are cuting into to make shure they are the right ones and if you run ito problems you use it to troubleshoot .  GB is one of the cheapest  available in terms of cost and quality, but if you only needed for this one install it will do ok.
xetmes
Silver - Posts: 586
Posted: May 26, 2003 at 6:35 PM / IP Logged
yea that should work, if you plan on using it again i would recommend an auto-ranging just because it makes life easier
Mr Akimoto
Member - Posts: 14
Posted: May 26, 2003 at 8:44 PM / IP Logged
I like the easy life. What's a good inexpensive meter? BTW Harbor Freight (or Tools) had one for $1.50!
Ciao!
molotov_icr
Member - Posts: 13
Posted: May 27, 2003 at 8:21 PM / IP Logged
I personally wouldn't use anything other than a Fluke.  But thats just me.  Try going to radioshack , sears, or you could probably get one of ebay, they have tons of cheap meters.
"If it's to loud, Then you're to old"
IronCy
Copper - Posts: 93
Posted: May 27, 2003 at 8:45 PM / IP Logged
Most wires, if not all wires (havent ran into a wire with a lot more then 12v--but my experience is limited)  will be 12v, in this case, you might want to look into a test probe rather than a dmm.  A probe will let you know if a wire is resting at ground or 12v.  This will be all that you will need...assuming you already have tech sheet--you will just be double checking wires.  Otherwise it would be very tiresome stripping each wire back so that you could check the voltage----apposed to just sticking it with a test probe.  A dmm will come in handy if you need to test resistors before installing them---newer cars these days require resistors.  I would say that you would be safe and be able to save some time by just getting a test probe---but you really should have both if possible.  Just my 2 cents
-Cy
amigoboom
Member - Posts: 10
Posted: May 27, 2003 at 9:25 PM / IP Logged
You Should Not Be Intalling This If You Do Not Know What To Do With A DMM!!!!
Mr Akimoto
Member - Posts: 14
Posted: May 29, 2003 at 9:02 AM / IP Logged
Well I bought one at Radio Shack. It was marked down from $69.99 to $29.99. It looks good, seems well built, and is very easy to use. I especially like the auto ranging. If any of you are interested, the model number is 22-801.
Ciao
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
