2012 ford focus
boomboomwagon
Posted: December 26, 2015 at 7:38 PM / IP Logged Link to Post Post Reply Quote boomboomwagon
I am working on my focus and have used the wiring secction of the forum to locate most of the wiring needed to do a amp to my factory head unit. I was going to use the the factory power antenna for the remote turn on with a relay tk cut down on power draw. But am having probloms locating it on my harness. Can somone pass along some info on what plug and where I might find this. Or what color wire and where I might find a ignition wire I could safly use with out causing problems.
Posted: December 27, 2015 at 2:00 AM / IP Logged Link to Post Post Reply Quote howie ll
Probably done Via DATA so forget that one. Use an ignition feed from the body control behind the glovebox.
