Viper 5806V to Camry 1999
mikecarstarter
Member - Posts: 7
Posted: January 09, 2016 at 10:31 AM / IP Logged Link to Post Post Reply Quote mikecarstarter
I joined pakring light from car (+) wire to (-)500mA lockoutput without any relay. Do i need to use one?
Same for unlock.
542440
Posted: January 09, 2016 at 10:46 AM / IP Logged Link to Post Post Reply Quote howie ll
Do me a favour remove everything and take it to a pro, that last comment doesn't even make any sense.
mscguy
Copper - Posts: 212
Posted: January 09, 2016 at 12:05 PM / IP Logged Link to Post Post Reply Quote mscguy
Listen to Howie. Tow it to a pro.
It sounds like you grounded out a coil wire with a test light and now your car won't start with a key? That is most likely an expensive mistake. You probably cooked your pcm.
mikecarstarter
Member - Posts: 7
Posted: January 09, 2016 at 7:29 PM / IP Logged Link to Post Post Reply Quote mikecarstarter
My batter drained off completely while i was check for starter relay other fuse.
Any suggest what should i do now.
542440
mikecarstarter
Member - Posts: 7
Posted: January 11, 2016 at 3:27 PM / IP Logged Link to Post Post Reply Quote mikecarstarter
There was EFI fuse blown, I replace with new one. It is working as it suppose to.
Can please confirm where should I connect following wire:
1. Key sense wire (blue/black) to which Viper harness and wire?
2. Factory disarm (RED / Green) Drive kick panel 24 pin connector to which alarm harness and wire
3. Door Trigger (RED / White) (Top Right of fuse panel/14 pin connector) - which alarm harness/wire
4. Door Unlock (Blue) connected to 3 pin connector (Blue) - Not working
5. Door Lock (Blue/White) connected to 3 pin connector (green) - not working
Any suggestion!
542440
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
