Increasing 4103 crank time
bochnak
Member - Posts: 6
Posted: January 11, 2016 at 8:06 AM / IP Logged Link to Post Post Reply Quote bochnak
Hi everyone,
I installed an Avital 4103LX remote start in my 92' accord. I did not run a tach wire, so I'm using virtual tach.
On cold mornings, the crank time is too short. It will start on it's second attempt, which is not a huge problem. The crank time is perfect once engine is warm.
My question is, does the virtual tach shut down the starter? If I increase crank time for cold starts, I'm worried that it will over crank once warm.
triniforever
Copper - Posts: 323
Posted: January 11, 2016 at 8:13 AM / IP Logged Link to Post Post Reply Quote triniforever
The tach wire is very easy to access on that car you dont you connect it ? Or you can change engine sensing to voltage sense and increase the crank time to 0.8 sec which is a lot better than virtual tach.
triniforever
bochnak
Member - Posts: 6
Posted: January 11, 2016 at 8:22 AM / IP Logged Link to Post Post Reply Quote bochnak
I did not connect the tach wire. If I can easily find that wire under the dash I may consider hooking it up.
So you recommend changing virtual tach to voltage (Menu 2 feature 1)? Also bump up crank time from .6 to .8sec?
Sounds like both virtual tach and voltage do not kill the starter. It still will crank for programmed time.
Does anyone know if I can find the tach wire under dash? Or do I have to run it to the distributor?
triniforever
Copper - Posts: 323
Posted: January 11, 2016 at 8:32 AM / IP Logged Link to Post Post Reply Quote triniforever
Virtual tach is a lot less reliable than voltage sense where the brain senses the increase in voltage when the car starts and disengages the starter,virtual tach is kinda like the remote start guess when the car starts and then disengages the starter and its not very reliable in cold weather.And i dont think ive ever found the tach wire on that car under the dash i might be wrong.
triniforever
bochnak
Member - Posts: 6
Posted: January 11, 2016 at 8:58 AM / IP Logged Link to Post Post Reply Quote bochnak
Are you telling me that in voltage mode, the starter will disengage when voltage increase is detected? On page 38 of the manual it states that it cranks for programmed amount of time. It does not state that it will kill the starter with voltage increase.
The manual should be a little more descriptive IMHO.
triniforever
Copper - Posts: 323
Posted: January 11, 2016 at 9:02 AM / IP Logged Link to Post Post Reply Quote triniforever
Yes the starter will disengage will voltage sense .
triniforever
bochnak
Member - Posts: 6
Posted: January 11, 2016 at 9:05 AM / IP Logged Link to Post Post Reply Quote bochnak
OK, thanks. I'll give it a shot.
davep.
Gold - Posts: 641
Posted: January 11, 2016 at 10:41 AM / IP Logged Link to Post Post Reply Quote davep.
The OP is correct. It does not stop cranking when it detects a voltage rise.
It cranks for the programed duration. Then a few seconds after it quits cranking, if it doesn't detect a voltage rise it shuts off the ignition because it 'failed to start'. DEI's make 3 attempts to start.
I know some CS130 GM alternators have an alternator regulator that doesn't 'turn on' until 10 seconds after engine start. This would be problematic with Voltage Sensing.
Posted: January 11, 2016 at 12:55 PM / IP Logged Link to Post Post Reply Quote howie ll
Tach will be blue wire at instrument cluster.
bochnak
Member - Posts: 6
Posted: January 11, 2016 at 1:20 PM / IP Logged Link to Post Post Reply Quote bochnak
OK, great thanks!
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
