2009 Toyota Corolla Remote Start?
Platinum - Posts: 7,783
Posted: January 23, 2016 at 7:54 PM / IP Logged Link to Post Post Reply Quote kreg357
Channel 4 does that.  I thought the issue was engaging the rear defrost automatically without an additional manual operation on the APS997E remote?
jcharley
Copper - Posts: 55
Posted: January 23, 2016 at 8:16 PM / IP Logged Link to Post Post Reply Quote jcharley
That was what I wanted to do but forr simplicity of the instal I'm going to follow your advice and use the channel 4 output. Thank you for all of your help. It's very much appreciated.
jcharley
Copper - Posts: 55
Posted: January 25, 2016 at 8:04 PM / IP Logged Link to Post Post Reply Quote jcharley
I need to use a relay for my channel 4 output according to the instal menu. My question is do I need to run the fused wire directly from the battery and what size fuse should I use.
Posted: January 25, 2016 at 8:13 PM / IP Logged Link to Post Post Reply Quote kreg357
Not sure that you need a relay.  Take a look at that Defroster wire at the switch, gray 10 pin plug.  If it is a thin gauge wire, no
relay is required.
Of course you can still use a relay.  The (+) relay coil, Pin 86, draws very little current, so a 2 amp fuse going to the same
R/S power source is fine.  Relay Pin 87 goes to chassis ground, Relay Pin 85 goes to Channel 4 output and Relay Pin 30
goes to the vehicles defroster wire.
jcharley
Copper - Posts: 55
Posted: January 25, 2016 at 8:44 PM / IP Logged Link to Post Post Reply Quote jcharley
Ok,thank you and just to clarify, when you say switch you are referring to a plug that does to the rear defrost button correct.
Posted: January 25, 2016 at 8:57 PM / IP Logged Link to Post Post Reply Quote kreg357
Yes, I believe so.  Verify that it is a Gray 10 Pin connector as indicated below.
US built
Rear Defrost TAN (-)  (LATCHED)         @ SWITCH, GRAY 10 PIN CONN, PIN 2
Japan built
Rear Defrost Black (-)  (LATCHED)        @ SWITCH, GRAY 10 PIN CONN, PIN 2
jcharley
Copper - Posts: 55
Posted: January 25, 2016 at 9:24 PM / IP Logged Link to Post Post Reply Quote jcharley
I have a few questions on another vehicle. I'm also working on A 2004 Chrysler Town & Country. Same R/S & Bypass (prestige aps997e with Flashlogic FLCAN bypass).
I have gotten the info needed to wire up the rear defrost that is (+) Latched and needs a HD relay but I want to known if I have to use relays for my sliding doors. The Install Manual says that when the Aux channels are used to use a relay.
Also the instructions for the bypass show the sliding doors need wired to the bypass from the R/S. Do they also need to be hooked into the sliding door wiring or just to the bypass.
jcharley
Copper - Posts: 55
Posted: January 29, 2016 at 1:31 PM / IP Logged Link to Post Post Reply Quote jcharley
Thanks for all of your help. I have gotten it all installed. I'm just wondering though. I have so many wires not being used and taking up a bunch of space under my dash. Should I cut them or what do you normally do wit the extra wires. For instance my 26 pin plug I'm only using 1 wire and the extras take up a lot of space.
geepherder
Platinum - Posts: 3,668
Posted: January 29, 2016 at 1:57 PM / IP Logged Link to Post Post Reply Quote geepherder
If you decide to cut them, make sure to leave several inches coming out of the plug so if you need to make changes, you can still connect on easily. Then you can bundle them together with tape, zip ties, heat shrink, etc.
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
