2013 Lexus RX350 PTS
wyciwug
Copper - Posts: 156
Posted: February 01, 2016 at 9:25 AM / IP Logged Link to Post Post Reply Quote wyciwug
I am about to do this car's remotestart using this
Bypass OEM-AL (RS) TL2 as the remote start itself
RF kit Compustar model: RF2W704SH2 Prime Remote Kit to extend the range
I heard that the Compustar kit has to be programmed when adding onto the Bypass.
Does anyone have any instruction to program this? And possible needing a installation diagram for the RF to the RS? Thank you
dcd
rs specialist
Copper - Posts: 175
Posted: February 01, 2016 at 2:56 PM / IP Logged Link to Post Post Reply Quote rs specialist
That is an Omegalink bypass, I do not think the Compustar product will program to that piece as they use different data protocols.
You will need to program the ftd-100 that comes with the compustar piece when connecting it to a compatible product.
wyciwug
Copper - Posts: 156
Posted: February 01, 2016 at 2:59 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello
I am using Idatalink bypass programmed to OEM-AL (RS) TL2
and compustar RF extended antenna
My bad, I do have the FTD-100 piece also.
D
dcd
rs specialist
Copper - Posts: 175
Posted: February 01, 2016 at 4:25 PM / IP Logged Link to Post Post Reply Quote rs specialist
When you flash the module for use with the compustar rf kit, it should tell you to program the ftd 100 at that time.
wyciwug
Copper - Posts: 156
Posted: July 23, 2016 at 10:23 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello
I've finished install Flash Logic bypass for this 2013 RX350 and it works fine.
However, I want to install an RF kit to extend the range. I have a Compustar RF-2W704-SH 2-Way LCD Remote Kit that used to work on a 2015 Camry V6 PTS. I removed it.
Can anyone help me to find out if this kit will be compatible with this Lexus? And How would I program it? If it is not compatible, what would you recommend for an RF kit?
dcd
wyciwug
Copper - Posts: 156
Posted: July 24, 2016 at 8:17 AM / IP Logged Link to Post Post Reply Quote wyciwug
I had Flash Logic FLCAN and compustar RF2W704SH2. They are not compatible with each other? Or RF2W704SH2 is not compatible with the lexus?
dcd
rs specialist
Copper - Posts: 175
Posted: July 27, 2016 at 12:04 PM / IP Logged Link to Post Post Reply Quote rs specialist
The compustar RF kit you are asking about is just an RF kit. There is no remote start system by that number.
What is the part number for the "remote start" that you are using. I know you are just using the integration module for it. Is it an FLcan, ALCA? That makes a difference as the FLCAN uses a different protocol than the ALCA. If you are using an ALCA it will need to be flashed to work with the Compustar RF kit. If you are using the FLCAN, then the Compustar RF kit is not going to work for you.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
