After Market door lock actuator rod connector
the12volt
Administrator - Posts: 3,955
Posted: February 17, 2016 at 8:23 AM / IP Logged Link to Post Post Reply Quote the12volt
tdi200, you're welcome.
Howie, the u-bolt rod clamps worked so much better than the screw type. They are easier to install, a lot stronger, and will never come loose with nylock nuts or lock washers. In fact, I've never had to service one yet.
After Market door lock actuator rod connector - Page 2 -- posted image. the12volt • Support the12volt.com
Posted: February 17, 2016 at 10:19 AM / IP Logged Link to Post Post Reply Quote howie ll
But then I've never had to service either type although I must admit the u-bolts will also take a thicker rod.
Trouble is I feel the problem is in the original mounting I can see from the photo that's going to give problems, if the clamp hadn't failed the motors would have burned out.
Before wiring up install the actuator and make sure everything moves freely, you're trying to achieve a push-pull that's parallel to the OEM rod.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
