2004 VW Passat TDI Alarm/Remote Start/Stereo Wiring
thevonster
Posted: February 22, 2016 at 8:47 PM / IP Logged
I need the car audio and security wiring color codes for a 2004 VW Passat tdi wagon. I am installing a pioneer stereo w/navigation and a DEI alarm w/remote start.
To talk goodness is not good. Only to do it is.
Chinese Proverb
frank_30
Member - Posts: 26
Posted: February 24, 2016 at 12:50 PM / IP Logged
2004 Volkswagen Passat      Vehicle Information
Item     Wire Color     Polarity     Wire Location
12 Volts     red (x2)     +     ignition harness
Second 12 Volts
Starter     RED / black     +     ignition harness
Second Starter     N/A
Ignition     black     +     ignition harness
Second Ignition     N/A
Third Ignition     N/A
Accessory     yellow/black     +     ignition harness
Second Accessory     N/A
Third Accessory
Keysense     red     +     ignition harness
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock     RED / green     -     driver door module in door
Power Unlock     RED / blue (double pulse)     -     driver door module in door
Lock Motor     BLACK/ blue     5wi     driver door module in door
Driver Unlock Motor     BLACK/ gray     5wi     driver door module in door
Passenger Unlock Motor     BLACK/ gray     5wi     passenger door module in door
Parking Lights (-)     N/A
Parking Lights (+)     GREEN/ red     +     headlight switch
Hazards     same as turn signal wires
Turn Signal (Left)     BLACK/ white     +     comfort module, 15 pin plug, pin 15
The comfort module is under the carpet in front of the driver seat, in a protective box.
Turn Signal (Right)     BLACK/ green     +     comfort module, 15 pin plug, pin 14
Headlight     yellow/brown     +     headlight switch
AutoLights
Reverse Light     blue/red     +     driver kick, harness to rear
Left Front Door Trigger     BROWN / yellow     -     comfort module, 23 pin plug, pin 1
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision     blue/gray     -     comfort module, 23 pin plug, pin 21
Trunk/Hatch Pin     BROWN / black     -     comfort module, 23 pin plug, pin 10
Rear Glass Pin
Hood Pin     BROWN / red     -     comfort module, 15 pin plug, pin 5
Trunk/Hatch Release     BROWN / gray to BROWN / green     -     comfort module, 23 pin plug, pin 2
The comfort module is under the carpet in front of the driver seat, in a protective box. The fuel door release is RED / green (+) in the driver kick, harness to rear.
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)
Factory Alarm Arm     arms with lock
Factory Alarm Disarm     disarms with unlock
Disarm No Unlock
Trunk Alarm Shunt
Tachometer     NOT blk/blue or grn/red (W8)     ac     any fuel injector
Wait to Start     N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense     WHITE/ blue comfort module, 23 pin plug, pin 15
Brake Wire     RED / black     +     brake pedal switch
Parking Brake     BROWN / white     -     parking brake switch
Horn Trigger     BLACK / YELLOW (alarm horn)     +     comfort module, 15 pin plug, pin 11
Wipers     BLACK/ grn (L), BLACK/ pur (H)     +     windshield wiper switch
Left Front Window (Up/Down)     motor part of module
Extended triggers on the power lock/unlock wires will roll the windows up/down, and close the sunroof. Use validity channels to control.
Right Front Window (Up/Down)     motor part of module
Left Rear Window (Up/Down)     motor part of module
Right Rear Window (Up/Down)     motor part of module
Sun Roof (Open/Close)     motor part of module
Sun Roof (Limit/Close)     N/A
Memory Seat 1     yellow/black     -     memory switch on driver seat
Memory Seat 2     yellow/red     -     memory switch on driver seat
Memory Seat 3     yellow/blue     -     memory switch on driver seat
Radio 12V     RED / blue     +     radio harness
Radio Ground     brown     -     radio harness
Radio Ignition     (CAN data bus)
Radio Illumination     (CAN data bus)
Factory Amp Turn-on     N/A
Power Antenna     N/A
Left Front Speaker (+/-)     RED / green - BROWN / green     +,-     radio harness
If equipped, the amplifier is under the passenger side of the rear deck.
Right Front Speaker (+/-)     red - BROWN / red     +,-     radio harness
Left Rear Speaker (+/-)     blue/white - BROWN / white     +,-     radio harness
Right Rear Speaker (+/-)     blue - BROWN / blue     +,-     radio harness
Center Channel (+/-)
Subwoofer (+/-)
Aux. Audio Input Left (+/-)
Aux. Audio Input Right (+/-)
RSE Video (+/-)
RSE Audio Left (+/-)
RSE Audio Right (+/-)
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
"throw it in the gutter and go buy another"
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
