2013 mazda 3, ads al ca
ricardoboston
Copper - Posts: 268
Posted: March 18, 2016 at 6:13 AM / IP Logged Link to Post Post Reply Quote ricardoboston
hi there i need a help to wire just one wire from the bypass ads al ca to the remote start i need to know on the ads al ca there i have a black /white wire that goes to the 2nd start wire and the 1 start wire to the brake wire my question is can i put the black /white wire to the 1 start wire along with the brake wire? it is just to avoid to do a relay for a 2nd start I'm following the schematic number 3 on the ads al ca thanks
Platinum - Posts: 7,783
Posted: March 18, 2016 at 7:39 AM / IP Logged Link to Post Post Reply Quote kreg357
Those two wires, Starter1 and Starter2, must be kept separate.  If your R/S unit can not supply two (+) Starter outputs, you must create one.  Typically, most R/S units have a selectable ignition output wire that can be strapped or programmed as a Starter output.  If that isn't possible, most R/S units have a (-) Starter output that you can use to control a relay for polarity conversion to the (+) the bypass module needs.
Starter1 going to the Brake pedal is used to fool the car into thinking someone is pressing the brake pedal ( to allow a remote start ).  Starter2 is going to the Bypass module to let it know that the R/S is actually trying to crank the engine so the bypass module can output a (-) PTS signal and temporarily not pass on to the R/S unit the Brake signal it picked up from the CAN bus ( which would shutdown the R/S's remote start sequence ).
ricardoboston
Copper - Posts: 268
Posted: March 18, 2016 at 3:30 PM / IP Logged Link to Post Post Reply Quote ricardoboston
ok so i need to wire a relay for second start wire so thats what i have to do ok thanks
syl20rochon
Copper - Posts: 298
Posted: March 19, 2016 at 6:02 AM / IP Logged Link to Post Post Reply Quote syl20rochon
What has been said is correct, if the car requires 2 separate starter output, they need to be isolated. I've done quite a few of Mazda 3 PTS and I know that the BLACK/ white for the ADSALCA doesn't need to wired to the R/S since is passes through the data communication wire between the remote starter and the bypass. BUT, I've seen is some installation that it needed to connected (1 or 2 out of hundreds installed). What brand of remote starter are you installing?
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
Tuesday, April 30, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
