2013 Ford Edge V6 standard key
groundzero2010
Member - Posts: 46
Posted: March 19, 2016 at 12:32 PM / IP Logged Link to Post Post Reply Quote groundzero2010
Working with a Python 5706p and Fortin EVO-ALL
DEI's install wires have changed since I last used one. The Fortin install diagram is pretty self explanatory but trying to match up the wires Fortin is asking for to the DEI 10-pin heavy harness isn't straight forward.
Fortin is looking for:
Start
Ign2
Ign1
Acc
12V
Ground
DEI 10-pin harness:
RED / Black - Fused 12V Accessory/Starter Input
Pink/Black - Flex Relay Input 87a keyside (if req'd) of Flex Relay
Pink/White - Ign2 / Flex Relay Output
Red - 12V Ign 1 input
Green - Starter Input (Key side)
Violet - Starter output (car side)
Orange - Accessory output
RED / White - Fused 12v Ign 2 / Flex relay input 87
Pink - Igntion 1 input/output
I'm not use to the flex relay wiring that DEI has going on now. Could someone possibly help in directing me to which wires would tie together between the DEI and car (fortin diagram) unit?
Attaching an image of the actual diagram from Fortin.
2013 Ford Edge V6 standard key -- posted image.
groundzero2010
Member - Posts: 46
Posted: March 19, 2016 at 12:41 PM / IP Logged Link to Post Post Reply Quote groundzero2010
Going off the diagram I'd assume these connections:
DEI --> Car
Pink/White --> WHITE/ Orange
Red --> GREEN/ Red
Pink --> Blue/White
Orange --> PURPLE / Green
Violet --> Blue/White -Cut (car side)
Green --> Blue/White -Cut (key side)
RED / Black ??
Pink/Black ??
RED / White ??
By the way, it was brought to my attention, on your abbreviation for circuit you use "CKT". There is not "K" in circuit. Should this possibly be CCT? - R. Robson
hahahahahahaha
smokeman1
Platinum - Posts: 1,588
Posted: March 19, 2016 at 12:49 PM / IP Logged Link to Post Post Reply Quote smokeman1
This might help:
https://www.the12volt.com/installbay/forum_posts.asp?tid=132562&tpn=1
groundzero2010
Member - Posts: 46
Posted: March 19, 2016 at 1:02 PM / IP Logged Link to Post Post Reply Quote groundzero2010
That's a great writeup! I found my issue. RED / Black needs to be connected to 12V as to push 12V to the starter during engage. Thanks for the help!
hahahahahahaha
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
