2016 Dodge Dart, Alarm/Remote Start, Stereo Wiring
winderf4s
Posted: May 02, 2016 at 3:36 AM / IP Logged
I am in need of a Audio Wiring Diagram for a 2016 Dodge Dart.
C.M.Blackwell
tonanzith
Gold - Posts: 593
Posted: May 22, 2016 at 5:16 PM / IP Logged
all i have is for the 2015
use a multimeter and compare.
2015 Dodge Dart      DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     red (70A)     +     BCM/dash fuse box, gray 2 pin plug (C1), pin A
Second 12 Volts     N/A
Starter     lt. blue/tan (for starter kill only)     -     BCM/dash fuse box, black 60 pin plug (C4), pin 49
Second Starter     PURPLE / brown Ignition Node/Keyless Ignition Node Module, blk 6 pin plug, pin 4
Ignition     pink/white (for ignition sense only)     +     BCM/dash fuse box, rear, gray 60 pin plug (C8), pin 48
Second Ignition     brown (for second ignition sense only)     +     BCM/dash fuse box, black 60 pin plug (C4), pin 3
Third Ignition     N/A
Accessory     BROWN / orange (for accessory sense only)     -     BCM/dash fuse box, black 60 pin plug (C4), pin 4
Second Accessory     N/A
Third Accessory     N/A
Keysense     N/A
Data Bus     WHITE/ lt. green (Security K Line)     data     Ignition Node/Keyless Ignition Node Module, blk 6 pin plug, pin 5
Can Bus High     gray (CAN IHS); gray/white (CAN C)     data     data link connector, black 16 pin plug, pins 3, 6
Can Bus Low     white (CAN IHS); yellow (CAN C)     data     data link connector, black 16 pin plug, pins 11, 14
Can Bus Sw     N/A
Power Lock     PURPLE / dk. green     - 330 ohms     BCM/dash fuse box, blue 60 pin plug (C6), pin 27
Power Unlock     (same as power lock)     - 100 ohms
Lock Motor     lt. GREEN/ lt. blue     5 wire     BCM/dash fuse box, black 32 pin plug (C5), pin 18
Driver Unlock Motor     tan/lt. green     5 wire     BCM/dash fuse box, black 32 pin plug (C5), pin 32
Passenger Unlock Motor     tan     5 wire     BCM/dash fuse box, black 32 pin plug (C5), pin 3
Parking Lights (-)     WHITE/ brown (see Tech Doc 1082)     -1130 ohms     headlight switch, black 6 pin plug, pin 3
Parking Lights (+)     WHITE/ yellow (L); WHITE/ gray (R)     +     BCM/dash fuse box, blue 60 pin plug (C6), pins 47, 3
Hazards     WHITE/ dk. blue     -     hazard sw or BCM/dash fuse box, rear, gray 60 pin plug (C8), pin 55
Turn Signal (Left)     WHITE/ lt. green (F); WHITE/ dk. green (R)     +     BCM/dash FB, blk 60 pin plug (C4), pin 31; blue 60 pin plug (C6), pin 4
Turn Signal (Right)     WHITE/ tan (F); WHITE/ yellow (R)     +     BCM/dash FB, blk 60 pin plug (C4), pin 46; blue 60 pin plg (C6), pin 17
Headlight     WHITE/ brown (need to relay isolate the switch)     - 660 ohms     headlight switch, black 6 pin plug, pin 3
AutoLights     WHITE/ brown (need to relay isolate the switch)     -2Kohm(off     headlight switch, black 6 pin plug, pin 3
Reverse Light     WHITE/ lt. green     +     BCM/dash fuse box, blue 60 pin plug (C6), pin 1
Left Front Door Trigger     purple     -     BCM/dash fuse box, blue 60 pin plug (C6), pin 50
Right Front Door Trigger     PURPLE / white     -     BCM/dash fuse box, blue 60 pin plug (C6), pin 51
Left Rear Door Trigger     PURPLE / gray     -     BCM/dash fuse box, blue 60 pin plug (C6), pin 36
Right Rear Door Trigger     purple / YELLOW     -     BCM/dash fuse box, blue 60 pin plug (C6), pin 33
Dome Supervision     yellow/lt. blue     +     BCM/dash fuse box, blue 60 pin plug (C6), pin 57
Trunk/Hatch Pin     PURPLE / orange     -     BCM/dash fuse box, blue 60 pin plug (C6), pin 35
Rear Glass Pin     N/A
Hood Pin     PURPLE / dk. blue     -     BCM/dash fuse box, black 60 pin plug (C4), pin 8
Trunk/Hatch Release     tan/lt. green     -     trunk release switch, black 4 pin plug, pin 2
Trunk Release Motor     tan / YELLOW     5 wire     BCM/dash fuse box, black 32 pin plug (C5), pin 14
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (transponder and ignition)
Trunk Alarm Shunt     N/A
Tachometer     dk. blue/blk, gray/blk, brn/blk, or brn/red (1.4L)     ac     any fuel injector, black 2 pin plug, pin 1
     On 2.0L and 2.4L models, the fuel injectors are BROWN / yellow, BROWN / dk. blue, BROWN / white, or BROWN / red.
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     dk. GREEN/ YELLOW (also need to open the blk grnd)     -     clutch switch, black 3 pin plug, pins 2, 1
Fuel Pump     dk. blue/orange     +     passenger kick, harness to rear
Rear Defroster     dk. blue     - latched     BCM/dash fuse box, black 60 pin plug (C4), pin 19
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     (CAN IHS)
Right Front Heated Seat     (CAN IHS)
Speed Sense     dk. GREEN/ brown (A/T); dk. GREEN/ purple (DDCT)     ac     TCM, black 94 pin plug, pin 85 or black 28 pin plug, pin 22
Brake Wire     dk. GREEN/ lt. green     +     brake switch or BCM/dash fuse box, black 60 pin plug (C4), pin 57
Parking Brake     dk. GREEN / WHITE     -     BCM/dash fuse box, blue 60 pin plug (C6), pin 44
Horn Trigger     gray / YELLOW     +     BCM/dash fuse box, black 32 pin plug (C5), pin 30
Wipers     BROWN / white (L); BROWN / orange (H)     +     BCM/dash fuse box, black 20 pin plug (C3), pins 9, 10
Left Front Window (Up/Down)     ORANGE / lt. green - ORANGE / white (base models only)     A     driver window switch, black 14 pin plug, pins 10 - 9
Right Front Window (Up/Down)     ORANGE / dk. blue - ORANGE / gray (base models only)     A     driver kick, door harness
Left Rear Window (Up/Down)     ORANGE / white - ORANGE / gray     A     driver kick, door harness
Right Rear Window (Up/Down)     ORANGE / dk. blue - ORANGE / lt. blue     A     driver kick, door harness
Sun Roof (Open/Close)     lt. blue - dk. blue (funct with ignition on only)     +     sunroof switch, black 6 pin plug, pins 2 - 4
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     red     +     radio, black 52 pin plug, pin 44 or white 22 pin plug, pin 12
Radio Ground     black     -     radio, black 52 pin plug, pin 43 or white 22 pin plug, pin 1
Radio Ignition     (CAN IHS)
Radio Illumination     (CAN IHS)
Factory Amp Turn-on     (CAN IHS)
Power Antenna     N/A
Left Front Speaker (+/-)     gray/purple - gray / YELLOW     +,-     radio, black 52 pin plug, pins 47 - 51 or white 22 pin plug, pins 22-21
     On models with amplifier, the speaker wires are gray/purple - gray / YELLOW at the amplifier behind glove box, black 16 pin plug, pins 8 - 16. The tweeter wires are gray/orange - gray / YELLOW at the amplifier, white 22 pin plug, pins 20 - 9.
Right Front Speaker (+/-)     dk. GREEN/ purple - dk. GREEN/ YELLOW     +,-     radio, black 52 pin plug, pins 46 - 50 or white 22 pin plug, pins 11-10
     On models with amplifier, the speaker wires are dk. GREEN/ purple - dk. GREEN/ YELLOW at the amplifier behind glove box, black 16 pin plug, pins 7 - 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 - 8.
Left Rear Speaker (+/-)     gray/white - gray/dk. green     +,-     radio, black 52 pin plug, pins 48 - 52 or white 22 pin plug, pins 20-19
     On models with amplifier, the speaker wires are gray/white - gray/dk. green at the amplifier behind glove box, white 22 pin plug, pins 10 - 21. The tweeter wires are dk. GREEN/ brown - dk. GREEN / WHITE at the amplifier, black 16 pin plug, pins 13 - 5.
Right Rear Speaker (+/-)     dk. grn/lt. grn - dk. grn/gy or dk. gn - dk. gn/wh     +,-     radio, black 52 pin plug, pins 45 - 49 or white 22 pin plug, pins 9 - 8
     On models with amplifier, the speaker wires are dk. green - dk. GREEN / WHITE at the amplifier behind glove box, black 16 pin plug, pins 9 - 1. The tweeter wires are dk. GREEN/ brown - yellow/gray at the amplifier, black 16 pin plug, pins 4 - 12.
Center Channel (+/-)     gray/brown - gray/orange     +,-     amplifier behind glove box, white 22 pin plug, pins 11 - 22
Subwoofer (+/-)     gry/brn - dk. grn/brn(1); gry/wht - dk. grn/wht(2)     +,-     amplifier behind glove box, black 16 pin plug, pins 14 - 6; 3 - 11
Aux. Audio Input Left (+/-)     lt. GREEN/ tan - lt. GREEN/ dk. blue     +,-     radio, bk 52P plg, pins 16-7; wh 22P plg, pins 3-4
Aux. Audio Input Right (+/-)     lt. GREEN/ lt. blue - lt. GREEN/ dk. blue     +,-     radio, bk 52P plg, pins 6-7; wh 22P plg, pins 2-4
RSE Video (+/-)     dk. GREEN/ brown - dk. GREEN/ orange (rear view cam)     +,-     radio, black 22 pin plug, pins 15 - 16
RSE Audio Left (+/-)     dk. GREEN / WHITE - gray/orange (CD changer audio)     +,-     radio, black 22 pin plug, pins 13 - 1
RSE Audio Right (+/-)     gray/white - gray/orange (CD changer audio)     +,-     radio, black 22 pin plug, pins 14 - 1
Satellite Radio 12 Volts     (built into radio)
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6 x 9 left front door
Left Front Tweeter     2.5 or 3.5 left front dash
Right Front Speaker     6 x 9 right front door
Right Front Tweeter     2.5 or 3.5 right front dash
Left Rear Speaker     6 x 9 left rear door
Left Rear Tweeter     3.5 left rear deck
Right Rear Speaker     6 x 9 right rear door
Right Rear Tweeter     3.5 right rear deck
Center Channel     3.5 top center of dash
Subwoofer     8 center of rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
Gary Sather
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
