5906v H1/6 Orange - 500mA Ground
goldmartaus
Posted: May 07, 2016 at 3:09 AM / IP Logged Link to Post Post Reply Quote goldmartaus
Hi Everyone.
I have installed a Viper 5906v. I am trying to use H1/6 to energize a relay to feed power to a set of movement sensors. Currently there is NO output from H1/6. The rest of the system works correctly.
Does H1/6 need to be programmed to work as I need?
Any help would be very much appreciated.
Posted: May 08, 2016 at 2:51 AM / IP Logged Link to Post Post Reply Quote howie ll
Silly question but have you tested when armed?
goldmartaus
Posted: May 08, 2016 at 2:59 AM / IP Logged Link to Post Post Reply Quote goldmartaus
Yes...
Posted: May 08, 2016 at 3:03 AM / IP Logged Link to Post Post Reply Quote howie ll
One more thing; check the voltage between your earthing (ground) point and all your fuses.
goldmartaus
Posted: May 08, 2016 at 5:45 AM / IP Logged Link to Post Post Reply Quote goldmartaus
99% of the system is working perfectly so I don't think it is an earthing issue but I will check again all the same. Thanks.
Platinum - Posts: 13,676
Posted: May 08, 2016 at 8:21 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Driving a relay with a Ground While Armed output will (as Howie would say) flatten your battery after a day or so. If you drive this thing everyday you may be safe. Just some food for thought.
Posted: May 09, 2016 at 1:14 AM / IP Logged Link to Post Post Reply Quote howie ll
Do you know Craig, I missed the part about driving the relay, that's a no-no and if the OP wired that relay wrong that would fry the GWA circuit.
Posted: May 09, 2016 at 7:58 PM / IP Logged Link to Post Post Reply Quote i am an idiot
He will be fine other than the flat battery. He did state 500 milliamp capacity. Typical Bosch/Tyco relay 160 mill.
davep.
Gold - Posts: 643
Posted: May 10, 2016 at 12:04 PM / IP Logged Link to Post Post Reply Quote davep.
160ma is 3.8 AmpHr per 24 hour period. Depending on battery size, age, and state of charge, one could probably use 40-ish Amp hrs and still be able to start the car. 10 days or so.
Posted: May 10, 2016 at 3:49 PM / IP Logged Link to Post Post Reply Quote howie ll
Not if the relay is activating a circuit drawing say 4 amps, then you'll have problems.
BTW, if the GWA doesn't work use one of the aux outputs and configure it as a GWA.
Thursday, June 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
