2006 Toyota Passo, Alarm Wiring
linormani
Posted: June 30, 2016 at 6:35 AM / IP Logged Link to Post Post Reply Quote linormani
Anyone have a alarm wiring diagram form 2006 toyota passo....especialy the lock and unlock contacts and indicators....cheers
Platinum - Posts: 13,667
Posted: July 01, 2016 at 8:36 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Battery     WHITE/ GREEN     (+)     IGNITION SWITCH HARNESS
Ignition 1     BLACK / YELLOW     (+)     IGNITION SWITCH HARNESS
Ignition 2     BLACK/ RED     (+)     IGNITION SWITCH HARNESS
Accessory 1     BLUE/RED     (+)     IGNITION SWITCH HARNESS
Starter 1     BLACK/ WHITE     (+)     IGNITION SWITCH HARNESS
Triggers
     Wire Color     Polarity     Location     Plug/Pin #     Note     Picture
All Doors     RED / YELLOW     (-)     IN PLUG AT VEHICLE FUSEBOX
Hood Trigger     PINK/BLACK     (-)     AT MODULE BEHIND RADIO
Trunk/Hatch     RED / WHITE     (-)     AT MODULE UNDER RADIO
Lighting
All Parking Lights     GREEN     (+)     IN HARNESS IN DRIVERS KICKPANEL
Posted: July 01, 2016 at 8:40 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Power Lock     GREEN / WHITE     (-)     IN HARNESS IN DRIVERS KICKPANEL
Power Unlock     RED / WHITE     (-)     IN HARNESS IN DRIVERS KICKPANEL
linormani
Posted: July 04, 2016 at 6:46 PM / IP Logged Link to Post Post Reply Quote linormani
hey dude i tried using the lock and unlock wires as you said but its not working....is it possible to get pictures of the connections....thank you very much for your help mate.....cheers
Posted: July 04, 2016 at 10:20 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I thought you made a typo. Toyota made a Paseo here in the states. Audiovox had info for a 2006, that is what I gave you. Checked directechs and that is when I figured out they did not make the paseo in 06. I have no info on your passo. What country are you in?
Posted: July 05, 2016 at 1:01 AM / IP Logged Link to Post Post Reply Quote howie ll
Unknown Toyotas, use a test light on the kickpanel plugs either side or the door switch.
linormani
Posted: July 05, 2016 at 3:31 AM / IP Logged Link to Post Post Reply Quote linormani
FYI i am at a test stage at da moment.....jus cant find da lock and unlock wires.....and cant find any infor online.....
