2015 Kia Sorento Alarm/Remote Start Wiring
lurch228
Silver - Posts: 1,338
Posted: July 30, 2016 at 9:19 PM / IP Logged
MAKE : KIA | MODEL : SORENTO | YEAR : 2015
Choose Make / Model / Year / Product of the car by typing the first letter + tab key or using mouse, and click select button. Also, click on each item to see the glossaries.
MAKE
MODEL
YEAR
PRODUCT
Item
Wire Color
Polarity
Wire Location
Photo / Note
12volts
red (40A)
ignition switch, black 6 pin plug, pin 1
Starter
green      +      ignition switch, black 6 pin plug, pin 3
Second Starter
N/A
Ignition
orange      +      ignition switch, black 6 pin plug, pin 4
Second Ignition
N/A
Third Ignition
N/A
Accessory
blue      +      ignition switch, black 6 pin plug, pin 2
Second Accessory
yellow      +      ignition switch, black 6 pin plug, pin 6
Keysense      lt. green to pink/black      -      key switch, white 6 pin plug, pin 5
Power Lock
green      -      dash fuse box, white 26 pin plug (K), pin 4
Power Unlock
BROWN / black (all doors); red (driver door only)      -      dash FB, wht 26 pin plg (K), pin 5; rear, white 26 pin plug (L), pin 6
Lock Motor
orange      5 wire      dash fuse box, black 36 pin plug (A), pin 8
Unlock Motor
blue      5 wire      driver kick, white 48 pin plug, pin 21
Parking Lights+
yellow/black (L); blue/orange (R)      +      dash fuse box, white 24 pin plug (D), pins 6, 5
Parking Lights-
blue      -      headlight switch, white 13 pin plug, pin 2
Hazards      yellow/black      -      dash fuse box, rear, white 16 pin plug (M), pin 10
Turn Signal(L)      pink/black (F); white (R)      +      dash fuse box, wht 36 pin plug (B), pin 6; wht 24 pin plug (D), pin 16
Turn Signal(R)      yellow/black (F); pink/orange (R)      +      dash fuse box, wht 36 pin plug (B), pin 32; wht 24 pin plug (D), pin 19
Reverse Light      pink      +      dash fuse box, white 24 pin plug (D), pin 4
Door Trigger
RED / black      -      dash fuse box, white 26 pin plug (K), pin 6
Dome Supervision
WHITE/ orange      -      dash fuse box, rear, white 26 pin plug (L), pin 1
Trunk/Hatch Pin
white      -      dash fuse box, white 26 pin plug (K), pin 24
Hood Pin
RED / black      -      dash fuse box, white 26 pin plug (K), pin 25
Trunk/Hatch Release
pink/org (rear handle sw); gray/blk (pwr tailgate)      -      dash FB, wht 26 pin plg (K), pin 13; overhd console, wh 6 pin plg, pin 5
Power Sliding Door      N/A
Factory Alarm Arm
brn/org (key lock); gry/og (detect)(Tech Doc 1300)      - and open      dash fuse box, white 26 pin plug (K), pins 10, 17
Factory Alarm Disarm
pink (key unlock); gry/org (detect)(Tech Doc 1300)      both -      dash fuse box, white 26 pin plug (K), pins 11, 17
Disarm No Unlock
(see factory alarm disarm)
Tachometer
blue or green      ac      cam pos sensor, engine front driver side, gry or blk 3 pin plg, pin 3 or 2
Wait to start      N/A
Brake Wire
yellow      +      driver kick, black or white 46 pin plug, pin 4
Parking Brake      gray/orange      -      dash fuse box, white 26 pin plug (K), pin 12
Horn Trigger
gray      -      driver kick, black or white 46 pin plug, pin 17
Memory Seat 1      GREEN/ black      -      memory seat switch, white 6 pin plug, pin 5
Memory Seat 2      gray      -      memory seat switch, white 6 pin plug, pin 6
Memory Seat 3      N/A      -
* The logo is registered trade mark of Kia Corporate.
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
