5902 Install door unlocking
stanward
Copper - Posts: 57
Posted: September 06, 2016 at 10:04 PM / IP Logged Link to Post Post Reply Quote stanward
Hello,
I am installing a Clifford 5902 with twin 535t window units and DBall2 into a 2005 Nissan Frontier.
Everything works fine, except when I vent the Windows after arming, the dome lights come on for 15-30 seconds(estimate, did not time them) but luckily it doesn't trigger the alarm.
Also, when venting the Windows (for a 2nd time) after arming the alarm, all the doors unlock.
stanward
Copper - Posts: 57
Posted: September 07, 2016 at 12:02 AM / IP Logged Link to Post Post Reply Quote stanward
Nevermind, I figured it out. I shouldn't have hooked up the OEM alarm arm and OEM alarm disarm wires.
lurch228
Silver - Posts: 1,338
Posted: September 07, 2016 at 12:17 AM / IP Logged Link to Post Post Reply Quote lurch228
What did you hook them up to so as to help the next person that has this issue?
stanward
Copper - Posts: 57
Posted: September 07, 2016 at 12:24 AM / IP Logged Link to Post Post Reply Quote stanward
Hello lurch,
I did connect the power lock and power unlock wires.
I also connected the "OEM alarm arm output" to the "factory alarm arm" wire at the BCM.
I also connected the "OEM alarm disarm output" to the "factory alarm disarm" wire at the BCM.
I disconnected the two wires and the alarm works perfectly now.
I believe Nissan has the factory alarm arms (when the doors lock) and the factory alarm disarms (when the doors unlock).
Hope this helps someone.
lurch228
Posted: September 07, 2016 at 2:10 AM / IP Logged Link to Post Post Reply Quote lurch228
Thanks for your reply.
