2013 Chevrolet Silverado 1500 Alarm/Remote Start Wiring
lurch228
Silver - Posts: 1,338
Posted: September 15, 2016 at 12:27 AM / IP Logged
Directwire
2013 Chevrolet Silverado 1500 - North America
Remote Start, Security, Keyless Entry, Accessories
Item Wire Color Polarity Wire Location
12 Volts RED / black (60A); RED / black (60A) + dash fuse box, black 40 pin plug, pins E3, F1
Second 12 Volts RED / white (x4) (15A each) + BCM left of strng column, blk plg, pins 1, 2, 3, 4
Starter purple (for starter kill only) + starter or underhood fuse box, black 50 pin plug, pin F1
Second Starter pnk/bk or pnk (r-code); wht (5V ref)(TechDoc 1605) +9600 ohms ignition switch or BCM left of strng column, lt. green plug, pins 2, 4
Ignition pink + ignition switch or BCM left of strng column, lt. green plug, pin 14
Accessory brown or yellow + ignition switch or BCM left of strng column, lt. green plug, pin 21
Second Accessory (same as second starter) +6300 ohms
Keysense (same as second starter)
Data Bus dk. green (low speed GMLAN) data PASS-Key III+ Module, black 5 pin plug, pin 4
CAN Bus High tan/black (high speed GMLAN) data data link connector, black 16 pin plug, pin 6
CAN Bus Low tan (high speed GMLAN) data data link connector, black 16 pin plug, pin 14
CAN Bus SW dk. green (low speed GMLAN) data data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10
Power Lock pink/black (except premium models) - BCM left of steering column, gray plug, pin 12
Power Unlock ORANGE / black (except premium models) - BCM left of steering column, gray plug, pin 11
Lock Motor gray (except premium models) 5 wire dash fuse box, gray 14 pin plug, pin A3 or A7
Driver Unlock Motor tan (except premium models) 5 wire dash fuse box, gray 14 pin plug, pin A5 or B4
Passenger Unlock Motor tan (except premium models) 5 wire dash fuse box, black 40 pin plug, pin F2
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm lt. green (except premium models) (dr key unlock) - BCM left of steering column, pink plug, pin 20
Disarm No Unlock (Passkey and ignition)
Parking Lights (+) brown (L); brown (R) + underhood fuse box, black 30 pin plug, pins A7, F7
Parking Lights (-) lt. blue - headlight switch or BCM left of strng column, white plug, pin 8
Hazards white - hazard switch or BCM left of strng column, lt. green plug, pin 19
Turn Signal (Left) lt. blue/white (F); yellow (R) + BCM left of steering column, brown plug, pins 4, 1
Turn Signal (Right) dk. blue/white (F); dk. green (R) + BCM left of steering column, black plug, pin 5; brown plug, pin 2
Headlight white - headlight switch or BCM left of strng column, white plug, pin 12
AutoLights dk. green (ground to turn off autolights) - headlight switch or BCM, white plug, pin 17
Reverse Light dk. blue + BCM left of steering column, brown plug, pin 7 or 11
Left Front Door Trigger gray/black (except premium models) - BCM left of steering column, pink plug, pin 10
Right Front Door Trigger tan/white (except premium models) - BCM left of steering column, pink plug, pin 8
Left Rear Door Trigger lt. blue/black - BCM left of steering column, pink plug, pin 15
Right Rear Door Trigger lt. GREEN/ black - BCM left of steering column, pink plug, pin 14
Dome Light gray (dome lamp); WHITE/ black (cargo lamp) + BCM left of steering column, white plug, pin 5; pink plug, pin 2
Hood Pin pink/black - hood switch or BCM left of strng column, black plug, pin 17
Tachometer NOT pink, pink/black, or pink/white ac any fuel injector
Wait to Start dk. blue - instrument cluster, black 20 pin plug, pin 17
Clutch Pedal dk. green - clutch switch, black 6 pin plug, pin D
Fuel Pump gray (except 4.8L, 5.3L, and hybrid) + underhood fuse box, black 30 pin plug, pin B5
Rear Defroster purple + latched driver kick, harness to rear
Mirror Defroster (same as rear defroster) (except premium models)
Left Front Heated Seat dk. blue or black - driver window switch, lt. gray 14 pin plug, pin 6
Right Front Heated Seat dk. blue or black - passenger window switch, lt. gray 14 pin plug, pin 6
Speed Sense dk. GREEN / WHITE (some models only) ac radio, brown 16 pin plug, pin 5
Brake Wire lt. blue/white (functions with ignition on only) + BCM left of steering column, brown plug, pin 6
Parking Brake lt. blue - parking brake switch or BCM left of strng column, brown plug, pin 16
Horn Trigger tan - horn switch or BCM left of strng column, brown plug, pin 18
Wipers gray + BCM left of steering column, brown plug, pin 20
Left Front Window (Up/Down) dk. blue - brown (except premium models) A driver window switch, black 8 pin plug (X2), pins E - D
Right Front Window (Up/Down) dk. blue - brown (except premium models) A passenger window switch, black 8 pin plug, pins E - H
Left Rear Window (Up/Down) dk. blue - brown A left rear window switch, black 8 pin plug, pins E - H
Right Rear Window (Up/Down) dk. blue - brown A right rear window switch, black 8 pin plug, pins E - H
Sun Roof (Open/Close) brown and dk. green (open) (func with ign on only) - sunroof switch, black 8 pin plug, pins 6, 1
Sun Roof (Limit/Close) orange and dk. grn (close) (func with ign on only) - sunroof switch, black 8 pin plug, pins 4, 1
Memory Seat 1 orange +2260 ohms driver window switch, lt. gray 14 pin plug, pin 5
Memory Seat 2 (same as memory seat 1) +4260 ohms
