Pioneer DEH-80PRS cutting out under vibration/hi
mlab
Posted: October 02, 2016 at 1:45 PM / IP Logged Link to Post Post Reply Quote mlab
Pioneer DEH-80PRS cutting out under vibration/high volume
I've done a lot of newbie testing , so this could be quick to diagnose.
Pioneer DEH-80PRS head unit starts cutting out or skipping continually and only stops if I keep the volume pretty low. Any attempt to raise volume at med-high levels makes the sound cut out repeatedly again.
Happens with radio as well (not CD skipping), only at higher volumes.
Happens with engine on or off, only at lower volumes with engine on (higher voltage read on screen).
Not running an amp, just HU and 4 speakers.
Does not happen with other Pioneer head unit used for testing, DEH-X9500BHS. So nothing wrong with wiring, speakers, etc. It's the HU.
HU plugged in and sitting on passengers seat, starts cutting out when I tap on the top cover with my fingers, near the heat sink or antenna, mostly. So, I know road vibration is what starts it.
Lower the volume, stops cutting out, raise the volume, cuts out again. Keeps doing this forever.
Tap on it again a few times and it fixes itself. I can raise volume to max levels again.
Tap again, starts skipping / cutting out again. Tap some more, fixes itself, and so on...
None of this happens with other head unit (DEH-X9500BHS).
Very willing to open the thing up and solder or replace parts. Just need to know what to look for.
Please help!
lurch228
Silver - Posts: 1,338
Posted: October 02, 2016 at 2:56 PM / IP Logged Link to Post Post Reply Quote lurch228
sounds like a bad solder connection.
Platinum - Posts: 13,667
Posted: October 02, 2016 at 10:24 PM / IP Logged Link to Post Post Reply Quote i am an idiot
http://www.yproxy.com/blog/wp-content/uploads/2008/07/bad_solder_joints.jpg
Above link is an image of 3 bad solder joints. Yours will be on the rear of the board either on the output IC which is directly attached to the heat sink, or near the antenna jack.
mlab
Posted: October 05, 2016 at 9:51 PM / IP Logged Link to Post Post Reply Quote mlab
Thanks a lot for that info. Could be exactly what I needed to know. You seem pretty sure! I have access to the repair manual for this HU so I'll try to find what you described.
Posted: October 06, 2016 at 9:00 PM / IP Logged Link to Post Post Reply Quote i am an idiot
From your description of your problem, I am very sure this is your problem.
infinity99
Member - Posts: 6
Posted: October 31, 2016 at 2:08 AM / IP Logged Link to Post Post Reply Quote infinity99
i am an idiot has it pretty down, I had this HU years back. Had to send it back to Pioneer. There are only really 2 things that can ever go wrong with this HU. A bad or faulty solder, or the board has grounded itself on the chassis somehow. Otherwise the 80-PRS is one of the most simple a, bulletproof, and clean HU's you can get.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
