1998 K1500 bypass
tintmaster2001
Member - Posts: 9
Posted: October 28, 2016 at 2:17 AM / IP Logged Link to Post Post Reply Quote tintmaster2001
Please help! Doing my second remote start on my 1998 Silverado and I have never installed a bypass, I just received a passlock SL2 and was hoping someone can show me a wiring diagram.
THANKS for any info.
geepherder
Platinum - Posts: 3,668
Posted: October 28, 2016 at 9:02 AM / IP Logged Link to Post Post Reply Quote geepherder
Here's a good place for reference: http://12voltinstallations.8m.com/photo.html
tintmaster2001
Member - Posts: 9
Posted: October 28, 2016 at 9:53 AM / IP Logged Link to Post Post Reply Quote tintmaster2001
Thanks!
tintmaster2001
Member - Posts: 9
Posted: October 31, 2016 at 5:24 PM / IP Logged Link to Post Post Reply Quote tintmaster2001
Hey guys still need some help. Where do I hook up the blue negative wire that goes to the remote start it just says "while running" THANKS!
geepherder
Posted: October 31, 2016 at 8:41 PM / IP Logged Link to Post Post Reply Quote geepherder
If you're using a relay like in the link, it goes to terminal 85. If you have a bypass interface, it should come with a diagram and show you where it goes.
tintmaster2001
Member - Posts: 9
Posted: October 31, 2016 at 9:20 PM / IP Logged Link to Post Post Reply Quote tintmaster2001
Is it necessary to use a relay? I'm trying to follow these instructions on this website http://fortin.ca/download/24951/passlock-sl2v2_revi.pdf
i just can't figure out where the blue wire goes on the remote start. I'm following number 4 diagram. thanks for your response geepherder.
rmotlyintrested
Member - Posts: 35
Posted: October 31, 2016 at 9:56 PM / IP Logged Link to Post Post Reply Quote rmotlyintrested
I'm not an expert but I think you'll find that it doesn't exactly say "while running", it says, "(-) while running". In other words, ground while running or "ground out" while running. There should be an output by that name on your remote start or it may also be called "status output". Hope this helps.
tintmaster2001
Member - Posts: 9
Posted: October 31, 2016 at 10:02 PM / IP Logged Link to Post Post Reply Quote tintmaster2001
Thanks will try it tomorrow.
tintmaster2001
Member - Posts: 9
Posted: November 01, 2016 at 8:05 PM / IP Logged Link to Post Post Reply Quote tintmaster2001
Still no luck, it starts for a second and dies. I programmed the bypass and hooked up the(-) blue wire "while running" wire to status output and nothing. 1998 K1500 bypass -- posted image.
geepherder
Posted: November 01, 2016 at 11:40 PM / IP Logged Link to Post Post Reply Quote geepherder
The problem may have nothing to do with your Passlock bypass, so tell us what system you're installing.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
