crimestopper/evo-all
chris051873
Member - Posts: 7
Posted: November 13, 2016 at 9:58 AM / IP Logged Link to Post Post Reply Quote chris051873
Hello All,
I have a 2014 chevy sonic with a manual transmission.
purchased a crimestopper RS7-G5 remote start and also an EVO-ALL from fortin.
I have installed both, had no issues programming the fortin for the bypass.
Remote start works doors perfectly, however it will only flash 7 seven times when i try the remote start, which means the manual transmission procedure wasn't followed correctly.
I have tried it numerous times with no success.
to my belief the evo-all is suppose to supply all the information the remoter start needs in order to work, right ?
any help is appreciated.
I have also contacted both companies for help as well, but have not heard back from them yet.
thanks
chris
rs specialist
Copper - Posts: 175
Posted: November 14, 2016 at 9:54 AM / IP Logged Link to Post Post Reply Quote rs specialist
How did you contact the companies?
I would suggest calling CrimeStopper,I have always had great success with their technical support.
It sounds like the vehicle is not seeing something in the procedure. I would recommend hard wiring door pins and hand brake.
chris051873
Member - Posts: 7
Posted: November 14, 2016 at 11:33 AM / IP Logged Link to Post Post Reply Quote chris051873
I emailed them to begin with, i called crimestopper on my lunch break.
very informative guy, orlando was his name.
you are correct, and he also thinks the same thing......
he thinks it is the e-brake......
i will see if there is time tonight to check it out..
stupid work always gets in the way lol
chris
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
