2001 bmw 325xi remote start wiring
rac0000
Posted: December 10, 2016 at 7:08 AM / IP Logged Link to Post Post Reply Quote rac0000
hey guys, I need the wiring schematic for a 2001 325xi to install a remote start. thanks
rac0000
wirewise
Moderator - Posts: 489
Posted: January 08, 2017 at 7:03 AM / IP Logged Link to Post Post Reply Quote wirewise
3 SERIES      1999-2004
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      BMW'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #4
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED / GREEN (+) and RED / BLUE (+)      @ IGNITION SWITCH HARNESS
STARTER      BLACK/ BLUE (+)      @ IGNITION SWITCH HARNESS
STARTER 2      N/A
IGNITION 1      GREEN (+)      @ IGNITION SWITCH HARNESS
IGNITION 2      PURPLE (+)      @ IGNITION SWITCH HARNESS
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      N/A
ACCESSORY /HEATER BLOWER 2      N/A
KEYSENSE      N/A
PARKING LIGHTS ( - )      N/A
PARKING LIGHTS ( + )      See NOTE #1
POWER LOCK      BLUE/RED (TYPE B)      @ GENERAL MODULE, 54-PIN PLUG, PIN 22, See NOTE #2
POWER UNLOCK      WHITE/ BLACK (TYPE B)      @ GENERAL MODULE, 54-PIN PLUG PIN 20, See NOTE #2
LOCK MOTOR WIRE      N/A
DOOR TRIGGER      RED / BLUE (+)      @ GENERAL MODULE 54-PIN PLUG, PIN 18, See NOTE #2
DOMELIGHT SUPERVISION      COMES ON WITH UNLOCK
TRUNK RELEASE      GRAY/GREEN (+)      @ GENERAL MODULE 54-PIN PLUG, PIN 17, See NOTE #2
SLIDING POWER DOOR      N/A
HORN      PURPL/BLUE (+)      See NOTE #3
TACH      BLACK (AC)      @ DIAGNSTIC CONNECTOR, PASSENGER SIDE OF ENGINE COMPARTMENT OR AT DATA LINK CONNECTOR UNDER DRIVERS DASH
WAIT TO START LIGHT      N/A
BRAKE      BROWN / WHITE (+)      @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM      DISARMS WITH UNLOCK
ANTI-THEFT      BMW'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #4      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: remove the LIGHT SWITCH Module from the dash and remove the cover, a ribbon cable connects the switch to the module will be exposed. With the switch facing towards you interrupt the 4th wire from the left with a relay.
NOTE #2: the GENERAL MODULE is a WHITE box located behind the GLOVE BOX. The 54-pin plug is the CENTER PLUG.
NOTE #3: the HORN wire is located at the HORN RELAY above the GENERAL MODULE, it is a GREEN RELAY
NOTE #4: BMW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module,
~wirewise~ Verify all wiring with your meter before making any connections!
