2017 Rav4, Viper 5305V and Flashlogic FLC
wyciwug
Copper - Posts: 156
Posted: December 12, 2016 at 10:11 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello members
I had this unit as you know it is remote start and alarm combo but i connected it over the weekend only with Remote Start for now.
The range suffered, It's about only 1000 feet compares to another combo at 1500 feet. The range is poor, is it because I only connect the wires for Remote Start? should I also connect the alarm wires to make the range to its fullest?
Thank you
dcd
Platinum - Posts: 7,786
Posted: December 16, 2016 at 7:36 PM / IP Logged Link to Post Post Reply Quote kreg357
The remote range should not be affected by the number of connections made. Usually the culprit is the antenna placement and the antenna harness run. The advertised range is, at best, under very ideal conditions and not what you find in a real life situation.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
