lost on dome lights
dports70
Member - Posts: 10
Posted: December 28, 2016 at 4:35 PM / IP Logged Link to Post Post Reply Quote dports70
2008 f150 w/ keyless entry, I'm trying to activate the dome light delay when unlocking truck. I've installed a compustart 800 everything else is working flawless, remote start, door lock, and unlock, just stuck with lights.
my remote start doesn't have a courtesy light wire so I'm trying to trigger it off the door unlock with a relay. i know that black / blue is dome light (+) and ORANGE / lt green is (-) , i have wired it the following way
lost on dome lights -- posted image.
#86 to unlock trigger.
#30 to BLACK/ blue
no luck, ham able to activate the light through the ORANGE / lt green with relay but it only stays on the 1 sec the relay pulses
any help would greatly be appreciated
chev104275
Gold - Posts: 1,428
Posted: December 28, 2016 at 5:19 PM / IP Logged Link to Post Post Reply Quote chev104275
I would think you would be better off using something like a dei 528T to trigger the dome lights off the unlock wire of the remote start
prince504
Copper - Posts: 108
Posted: December 28, 2016 at 5:32 PM / IP Logged Link to Post Post Reply Quote prince504
@chev104275 are you familiar with the DEI 535T window roll up module? Ever installed one?
dports70
Member - Posts: 10
Posted: December 28, 2016 at 6:10 PM / IP Logged Link to Post Post Reply Quote dports70
would you be so kind as to share how this would be wired up?
chev104275
Gold - Posts: 1,428
Posted: December 28, 2016 at 8:01 PM / IP Logged Link to Post Post Reply Quote chev104275
Yellow = Ground
Brown = To dome light - trigger wire in vehicle
Black w/stripe = To unlock output - from alarm
Black = Ground
Red = +12V Fused supply
I believe your dome light wire is ground triggered
DOOR TRIGGER     BLACK / YELLOW (-)     A DRIVERS SIDE KICK PANEL
DOMELIGHT SUPERVISION     USE DOOR TRIGGER
Test to confirm
I know the older 04 -07 trucks are positive triggered so it could depend on build date   if you find it is positive trigger then you would put the yellow to 12v
DOMELIGHT SUPERVISION     BLACK/ LIGHT BLUE (+)     IN DRIVERS KICK PANEL, GRAY Plug, Pin 6
dports70
Member - Posts: 10
Posted: December 28, 2016 at 8:05 PM / IP Logged Link to Post Post Reply Quote dports70
chev104275 wrote:
Yellow = Ground
Black = Ground
Test to confirm
yes the ORANGE / lt green is (-) and triggers light on, thank you for the awesome responces
chev104275
Gold - Posts: 1,428
Posted: December 28, 2016 at 8:06 PM / IP Logged Link to Post Post Reply Quote chev104275
No problem good luck
brownsfan1
Copper - Posts: 65
Posted: December 30, 2016 at 7:16 AM / IP Logged Link to Post Post Reply Quote brownsfan1
I'm pretty sure that compustar has a dome supervision output. It will be a negative output and you will need a relay to trigger it.
dports70
Member - Posts: 10
Posted: December 30, 2016 at 7:59 AM / IP Logged Link to Post Post Reply Quote dports70
The 800 model does not, unless it's not labeled
brownsfan1
Copper - Posts: 65
Posted: December 31, 2016 at 11:13 PM / IP Logged Link to Post Post Reply Quote brownsfan1
You are right. I just looked at one I had in stock. I guess it's not a popular option. Because I looked at the Python 4105 I have and they don't have the output either. You have to go to a higher model
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
