Avital cranks for a split second when cold
nrmskate
Member - Posts: 13
Posted: January 04, 2017 at 8:35 AM / IP Logged Link to Post Post Reply Quote nrmskate
Hey guys, I'm having an issue with an Avital 4113lx system that I installed for a customer. If it's above 20 degrees outside the truck starts up no problem, but when it's around the 0 degree mark, the truck will literally bump the starter for the slightest moment then stop. It'll do this 3 times and then never starts. I've increased the cranking time from .6 seconds to 1.6 seconds and relearned the tach and I'm still having this issue. Anyone have any ideas?
scottgardner795
Member - Posts: 6
Posted: January 04, 2017 at 4:18 PM / IP Logged Link to Post Post Reply Quote scottgardner795
What type of truck? Maybe try temporarily disconnecting the tach and relying on a timed crank to determine for sure that it is a tach issue and not possibly something else. If it starts with a timed crank you can try a different/better tach connection, reprogram and eliminate timed crank completely.
scottgardner795
Member - Posts: 6
Posted: January 04, 2017 at 4:21 PM / IP Logged Link to Post Post Reply Quote scottgardner795
Also, each time you program the tach I believe the unit is taken out of the timed crank mode so you then are only using the supplied tachometer signal. You can't use both options.
nrmskate
Member - Posts: 13
Posted: January 04, 2017 at 6:48 PM / IP Logged Link to Post Post Reply Quote nrmskate
That is something that I was not aware of, if that's the case, I can simply turn the TACH to OFF in the menu settings. Thanks!
pentavolvo
Copper - Posts: 241
Posted: January 04, 2017 at 9:15 PM / IP Logged Link to Post Post Reply Quote pentavolvo
IMO you need to set programming to tach and learn the tach I bet you aren't in tach mode
nrmskate
Member - Posts: 13
Posted: January 05, 2017 at 8:08 AM / IP Logged Link to Post Post Reply Quote nrmskate
I believe I am in Tach mode, as I switched it from Virtual Tach to Tachometer signal, and did the corresponding Tach learn process as well.
jnz1
Copper - Posts: 109
Posted: December 19, 2017 at 1:53 PM / IP Logged Link to Post Post Reply Quote jnz1
What was the solution to this? I have an escape doing the same thing.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
