Ignition wire 2003 tahoe
1978malibu
Member - Posts: 23
Posted: January 14, 2017 at 2:54 PM / IP Logged Link to Post Post Reply Quote 1978malibu
Hello everyone, I have a 2003 tahoe lt. I want to install a new radio but I'm having a hard time finding ingredients power. Can I use the big pink wire as ing. It has ing power with key on and no power with key off
wisco_install
Member - Posts: 17
Posted: January 22, 2017 at 11:44 PM / IP Logged Link to Post Post Reply Quote wisco_install
You could, However you should be using a wire harness to connect the aftermakrket radio. Hopefully you haven't already cut off the factory plug. I can let you know what wire harness you need but I need to know if it
has the factory Bose system and does it have on star? Thanks
soundnsecurity
Gold - Posts: 2,711
Posted: January 28, 2017 at 4:51 PM / IP Logged Link to Post Post Reply Quote soundnsecurity
if your factory radio was a BOSE system then it will need more than just ignition power, the radio will turn on but you will either get no sound because the factory amp needs to be turned on too. the factory amp uses a data signal from the factory radio to turn on and that is the main job of the adapter harnesses. OR, you can run speaker wires to the factory speaker wires located at the factory amp. it really depends on exactly which level factory system came stock in your tahoe.
Platinum - Posts: 13,667
Posted: January 28, 2017 at 9:57 PM / IP Logged Link to Post Post Reply Quote i am an idiot
There are very few premium bose systems out there. If it is a premium bose system it will require hardware to turn the amplifier on. If non premium it will simply require 12 volts on the amp turn on wire. To tell if it is premium, simply turn the volume up quickly, if the sound quickly changes you do not have a premium bose system. The volume will gradually go up on the premium system.
soundnsecurity
Gold - Posts: 2,711
Posted: January 30, 2017 at 3:02 PM / IP Logged Link to Post Post Reply Quote soundnsecurity
good point, i guess ive been away for too long. i must be slipping
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
