If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Above picture is of an 04 yukon or tahoe with bose. For reference the air conditioner control is mounted. The plug in the picture is attached to the 4 speakers of the vehicle. If there is a harness attached to your aftermarket radio, simply plug the pictured harness into the harness. No need to change anything. That harness has Constant, ground and data.
