Dimmer Scion xB 2004 (resolved)
hot lava 1369
Posted: May 07, 2017 at 7:38 AM / IP Logged Link to Post Post Reply Quote hot lava 1369
I added some aftermarket gauges with led bulbs when I hooked them up to the factory dimmer they work backwards. If I switch the wires around they don't work at all. any help on the wiring. I also have a spare dimmer I can use but I also don't know the wiring diagram for it it's a Toyota dimmer 5 wires part number F11cs2 thanks john
John
Platinum - Posts: 13,667
Posted: May 07, 2017 at 5:30 PM / IP Logged Link to Post Post Reply Quote i am an idiot
You connected one of the wires to the factory dimmer wire. What did you connect the other wire to?
hot lava 1369
Posted: May 07, 2017 at 6:02 PM / IP Logged Link to Post Post Reply Quote hot lava 1369
I taped into one wire and than hooked up a ground wire
John
hot lava 1369
Posted: May 07, 2017 at 6:07 PM / IP Logged Link to Post Post Reply Quote hot lava 1369
I messed around with a few dimmers I have but couldn't get any to dim the led. Got them to light , maybe the dimmers are to strong for the low draw of the led. No clue how to test that. Thank for any help John
John
Posted: May 07, 2017 at 7:30 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Was that wire White/Green, and located in the small radio harness? If so, connect the LED ground wire to that wire. Connect the LED power wire to the Green wire in the big radio harness, or at the headlight switch.
hot lava 1369
Posted: May 07, 2017 at 9:19 PM / IP Logged Link to Post Post Reply Quote hot lava 1369
Yes it was the white and green wire tapped into it just behind the dimmer will try your suggestion tomorrow thanks John
John
hot lava 1369
Posted: May 09, 2017 at 4:27 PM / IP Logged Link to Post Post Reply Quote hot lava 1369
I followed your advice and it was spot on works great now thanks. John
John
