2005 chevy equinox aftermarket stereo installati
dusty krueger
Member - Posts: 6
Posted: June 24, 2017 at 6:52 PM / IP Logged Link to Post Post Reply Quote dusty krueger
I am attempting to install a poineer Dxt-x4869bt stereo in my 2005 chevy equinox but cant figure out the wires and cant buy the aftermarket harness to make it easier because the previous owner cut the factory harness out.
Platinum - Posts: 13,725
Posted: June 24, 2017 at 7:42 PM / IP Logged Link to Post Post Reply Quote i am an idiot
What color wires do you have? Is there a larger than the rest Red with White stripe? Is there a pair of greens, one dark and one light? Is there a pair of blues, one dark and one light? Is there an orange?
dusty krueger
Member - Posts: 6
Posted: June 24, 2017 at 8:14 PM / IP Logged Link to Post Post Reply Quote dusty krueger
Yes i have all of those. I got it to turn on by crossing the red and yellow and will just have to manualy shut off the radio. But now my new problem is my amp isnt working
Posted: June 24, 2017 at 9:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Red white is constant power. B;acl/White is ground. There is no switched power, you need to find a wire on the AC control that goes on and off with the key. Orange is the amplifier turn on. Grey front left positive. Tan front left negative. Light green front right positive. Dark green front right negative. Brown left rear positive. yellow left rear negative. Dark blue right rear positive. light blue right rear negative.
dusty krueger
Member - Posts: 6
Posted: June 24, 2017 at 10:08 PM / IP Logged Link to Post Post Reply Quote dusty krueger
Ok i will try
dusty krueger
Member - Posts: 6
Ok i will try that and let you know
dusty krueger
Member - Posts: 6
Posted: June 24, 2017 at 10:26 PM / IP Logged Link to Post Post Reply Quote dusty krueger
Ok that worked but my only question is what are the 2 purple wires the skinny blue wire not thicker blue speaker one and the white with black stripe
Posted: June 25, 2017 at 8:15 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Insulate the ends so they will not touch anything. They are not needed for an aftermarket radio. One of them is the data wire that controlled the OEM radio.
dusty krueger
Member - Posts: 6
Posted: June 25, 2017 at 10:05 AM / IP Logged Link to Post Post Reply Quote dusty krueger
Ok i did that everything works good.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
