AC not turning on with remote start, '11 Kia Forte
k9cuevas
Member - Posts: 6
Posted: July 27, 2017 at 6:18 PM / IP Logged Link to Post Post Reply Quote k9cuevas
Hi,
I just installed a Directed Electronics (Viper) 4105V remote start and keyless entry. I followed the install instructions and I also had the wiring diagram for my specific vehicle. Everything works perfect as far as starting and shutting off, lock and unlocks, and trunk release. The issue I am having is when I remote start the vehicle the air conditioner or heater does not turn on. I replaced an existing remote starter that went bad and it all worked before it went bad. Has anyone else had this issue? What do I need to do? Thanks in advance.
Orlando C.
k9cuevas
Member - Posts: 6
Posted: July 27, 2017 at 6:19 PM / IP Logged Link to Post Post Reply Quote k9cuevas
I have a 2011 Kia Forte
Orlando C.
lectricguy
Copper - Posts: 359
Posted: July 27, 2017 at 8:21 PM / IP Logged Link to Post Post Reply Quote lectricguy
Check the presence of 12V on these wires when running under remote start:
ACCESSORY/HEATER BLOWER 1     ORANGE (+) NOTE #3     @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 3
ACCESSORY/HEATER BLOWER 2     YELLOW (+)     @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 4
NOTE #3: this wire may need to be RELAY ISOLATED to prevent STARTER GRIND upon Key Take Over.
On the 2010-2011 The orange wire Acc 1 wire needs to be opened using a relay using the GWR wire during remote start to avoid starter grind on key take over. Was this hooked up on the old remote start, and did you miss connecting up this relay when you replaced the old unit?   Could be that the relay is there, just open, not allowing the ACC1 wire to be powered....
Lectric Guy
chev104275
Gold - Posts: 1,428
Posted: July 27, 2017 at 8:24 PM / IP Logged Link to Post Post Reply Quote chev104275
Can you list your wiring so we can get a better picture of what's going on.
Also check out the pictorial I made and compare your wiring to it.
Sounds like you missed a wire.
Kia Forte pictorial
k9cuevas
Member - Posts: 6
Posted: July 27, 2017 at 8:56 PM / IP Logged Link to Post Post Reply Quote k9cuevas
There was a relay that was wired into the previous remote start. I kept it in and wired the remote start accy 2 wire to that. I will double check power there tomorrow. All the wires are connected per the instructions. Thanks and I will let you know if I find anything there.
Orlando C.
k9cuevas
Member - Posts: 6
Posted: July 27, 2017 at 8:58 PM / IP Logged Link to Post Post Reply Quote k9cuevas
I'll post the wiring as well. I'll take a pic of the vehicle diagram as well as the installation diagrams.
Orlando C.
k9cuevas
Member - Posts: 6
Posted: July 28, 2017 at 10:59 AM / IP Logged Link to Post Post Reply Quote k9cuevas
Ok so I tested the wires and retraced all my connections. I have pulled the relay out and hooked it up direct with out the relay in line and everything works as it should. I am not confident in the way everything was hooked up before as they eliminated some wires as well as tied some together to one point versus putting them where they needed to be. Since I ripped everything out and started from scratch I am confident that the wires are where they need to be.
I will need to buy a new relay and put it back in due to the starter grind on key take over. Can someone send me a diagram on how to hook this relay up correctly or at least send me which wires go to what.
Thanks again for all your time and help.
Orlando C.
chev104275
Gold - Posts: 1,428
Posted: July 29, 2017 at 5:04 AM / IP Logged Link to Post Post Reply Quote chev104275
Wire the relay like this
86 to ingition
85 to Ground when running from remote start should be (blue/white on your system)
87A to one side of cut acc wire
30 to the other side of cut acc wire
Diode across terminals 86 and 85 band facing 86
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
